Results 1 to 4 of 4
    Mar 2017
    florida
    Default battery charging
    can a battery tender plug into 12 volt outlet in trunk and work?
    Jan 2015
    southern WI
    Yup, provided you have the outlet set up to be "hot" all the time. If your battery is up in/behind the frunk though, I'd recommend just installing a pigtail for a tender directly to your battery, and let the pigtail hang in the frunk.
    2021 RT Limited
    2016 RTS , Pearl White
    Jul 2014
    Mint Hill, NC
    My Battery Tender Jr. pigtail in the frunk is fused and is the same amperage as my emergency compressor fuse so it can do double duty should I need the compressor on the road.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default Yeah....
    We just had a thread on that...as long as the outlet is powered constantly you can charge through it. Many are switched and you have to swap the feuses at the #6 and #7. Some tenders come with the cig lighter adapter...
    ​2012 RS sm5
