Results 1 to 5 of 5
    Apr 2017
    corpus christi, texas
    Default Bluetooth interface
    Has anyone tried to pair up JM Bluetooth headset with the Sena SM10 Bluetooth dongle.....can not get any help from JM ....The JM product has 4.1 technology and the Dongle is 2.1 tecnology.....i am challenged by these new Bluetooth products.
    Aug 2013
    SF Bay Area
    I would first make sure both headsets firmware is up to date. Connecting them to a computer to run firmware update programs. Both bluetooth versions also needs to be compatible. Then try pairing from one to the other. What I mean is pair from the J&M to the Sena and if that doesn't work pair the other way. If all else fails, call Sena or J&M.
    Good Luck
    2021 F3 Ltd , Magna Red
    Apr 2017
    Good Luck
    That's the problem ....JM Will not return calls or answer emails......anyone want to buy a new JML MODULAR helmet with blue tooth headset installed?
    Quote Originally Posted by donrokon View Post
    Call Motorcycle Dave. He can help you out. His ad is on the Home page.
    Aug 2013
    SF Bay Area
    Im guessing you followed the instructions for pairing to a BT device?
    https://www.jmcorp.com/pdf/HS-BT03--...ual01-2017.pdf
    Reading the pairing instructions, it says to put device into paring mode then put the J&M headset into pairing mode and they will pair. One hint - Turn off the BT on any other devices so that only the headsets are communicating with each other.
