Results 1 to 20 of 20
    Mar 2015
    Brockport, NY
    Default Looking for machinist help
    I have a Kohler motor on a bercomac snowblower. On the base of the Kohler motor there are 2 small metric m12x1.5 hex bolts that you have to remove to drain the oil. My problem is that there is no clearance to slip a funnel or anything else under the bolt and the oil ends up running down the side of the housing all over the floor. Simple solution would be a standard pipe nipple, but for the life of me I can not find a metric threaded pipe nipple. So I thought I’d ask this group and hope someone who has the right tools could possible fabricate me a short pipe, say 2-3” with a male threaded m12x1.5 end and any size male sae thread that I could cap. Id be more than happy to cover costs associated.
    2014 RT-S Pearl White
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by Brentc View Post
    .... a male threaded m12x1.5 end .....
    How about using a Fumoto Valve like this... http://www.fumotousa.com/parts.php?partnumber=36
    Then just slip on plastic tubing when you need to drain the oil.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Jun 2014
    People's Republic of NY
    How bout cutting a gallon water bottle so it slips up to the drain, the other end is over or in
    your drain pan
    committee for postings
    Mar 2015
    Brockport, NY
    Default Saw those.
    I dont have have the clearance to thread that on. The existing hex bolt head is about as much room as I have.
    Quote Originally Posted by nhoj View Post
    Mar 2015
    Brockport, NY
    Default Tried that.
    Quote Originally Posted by vided View Post
    your drain pan
    That was my first try, no matter how tight I tried to hold the bottle oil just seeped through and down the side. Very frustrating to say the least.
    Get in touch with Machinegunner (Ron). He can build anything!!
    Very Active Member Joe T.'s Avatar
    Jul 2014
    Wichita, KS
    I would think any Canadian hardware store would have the nipple you need. Perhaps you could find it online?
    Check these guys out, and I am sure there are many more sources:
    https://us.misumi-ec.com/vona2/detail/110300307150/
    Joe T.
    Joe T.
    I miss SoCal - - - -
    Very Active Member spacetiger's Avatar
    Sep 2013
    N. Va
    Good write up with a pic that really helps.
    I think your possible solution will work nice.
    While you are waiting, I'd suggest you tip the snowblower to the side so the oil drains out at an angle rather than straight down. The lean might help give you enough clearance.
    Jerry
    13 ST Limited F/R suspension, Corbin, GIVI top case
    16 Vespa Primavera 150: Stock
    16 Piaggio BV350: Suspension, braking mods in work
    14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
    09 Aprilia SC250: F/R suspension and minor brake mods
    97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
    90 CB-1: In work, long term project
    89 Honda NT650: F/R suspension; Corbin saddle
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    It looks like you could loosen the bolts that hold the engine down and raise it enough to thread in the adapter, or grind the frame for more clearance.
    Bob S
    Oct 2013
    rome new york
    Contact Kohler they do make drain kits.
    We sell their motors
    Mar 2015
    Brockport, NY
    Default Awaiting reply
    Quote Originally Posted by bmccaffrey View Post
    I emailed their support folks today.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    I was thinking you could loosen the bolts holding the engine dawn and slip a piece of shaped aluminum under there to act as a drain funnel?
    I've done this two trucks after relocating the oil filter between the engine and wheel well. That way the oil drains to a point after removing the oil filter.
    I do like the device you attach a tube for draining.
    Oct 2010
    Wisconsin Rapids
    Thanks, Bob. I just welded a British BREN gun back together. Going to test it today.
    Oct 2010
    Wisconsin Rapids
    How close to the metric thread size is 3/8npt size? If the threads are the same number per inch, a 3/8 pipe tap could be run in just to change the taper. Many metric and SAE threads are the same or within maybe 1/2 thread per inch witch would be of no consequence. The M12.5 bolt and the 3/8nps use the same 27/64 drill size for the tap.
    Apr 2013
    Wisconsin
    I would look for a M12 hydraulic fitting.
    Active Member chisel_maker's Avatar
    Mar 2012
    Evergreen, CO
    2011 RTS SE5
    Mar 2015
    Brockport, NY
    Default Thanks for that info
    Ill look into the hydraulic fittings. They show some promise with the small diameter they have. So far most of the adapters are to wide and my situation is a little bit recessed and the adapters won’t clear the space.
    Quote Originally Posted by Bert-RFD View Post
    Sep 2014
    USA
    Idaho
    Those three links above are exactly what you are looking for! Those guys did a better job than I did Googling for a solution. I didn't find those at all!
    2014 Copper RTS
    Mar 2015
    Brockport, NY
    Default I ordered fitting this morning
    Thanks everyone. I ended up ordering a 12mm x 1.5 male to 1/2 male adapter. Should be here mid week. Thanks for all the links and suggestions.
    Now I just hope the snow holds off till then, as my snowblower is sitting without oil in the crankcase.......
