Rear Brake Caliper
OK, I am helping a friend change the rear brake pads on his 2014 RT, we have the caliper off the bike and start screwing the piston into the body by turning it clockwise to compress the piston, only the piston just spins it doesn't screw into the body! We turned the piston at least 50 full revolutions so I'm sure something is not right. Any ideas why?
Thanks, Kent
Ride Safe All
2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
Thanks, Kent
I've completed my rear brake change twice on my 2014 RTL. Clockwise is correct and I apply slight pressure to "push" the piston in while turning it clockwise. I think it only takes a few revolutions at most to get it all the way back. I don't know why yours spins and does not compress. NEVER us a c-clamp to compress the back piston (which I think you know), turning it clockwise should do the trick.....sorry, maybe others can help with a solution! Good luck!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Haven't used a c-clamp and used inward pressure when turning the piston. On my bike it worked "easy peasy", this bike, something is amiss and I just do not know what? However thanks fir the suggestions, any and all are very much appreciated.
Kent
Ride Safe All
Are you using a pair of needle nose pliers, using them to insert into the 2 holes on the piston while turning it clockwise?
PLIERS ? ? ?
A lot of the automotive parts stores sell a tool to turn in the pistons on automobiles. Someone should measue the distance between the pin holes and measure the hole size. When they have there's apart. And post it here.
Brakes
Hi there. What I did was carefully opened the black rubber surrounding the Piston and sprayed some brake cleaner. Sometimes dirt gets in there and prevents piston to turn. Happened to me and that worked for me. Good luck.
Thanks to all the suggestions, but turning the piston isn't the issue, I can turn it all day long, it just doesn't retract into the caliper body? It will be going to the dealer soon and they can deal with it. Guessing something is wrong insde the Caliper.
Kent
Ride Safe All
SpyderLovers Ambassador
Rear Brake Piston
I was told that this is a two part piston. Usually the end will screw into the piston. But if the threads got damaged this will cause the two part piston to not retract. Sometimes it is human error and or a rust/dirt issue. Try using WD 40 or some type of 'Rust Blaster'. This works sometimes. Good Luck and let everyone know the outcome. Little Blue
Harbor freight has the piston tools too.
Bike will be going to the dealer, under warranty so they can deal with it. I'll report back with their finding. Thanks all.
Kent
Ride Safe All
Kent
I had the exact problem. Trailered it to the dealer today. They had to take the assembly apart and clean it. Cost me over $100 but worth it.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
Thanks, good to know.
Ride Safe All
Yup, a $100 is worth stopping!!!!
I'm resurrecting this thread. Working on another 2014 RT and the same thing, I cannot get the Rear Caliper Piston to Retract. I have done 2 other bikes and no problem. What is the solution? I got to believe there is a fix besides replacing the caliper? Cheap Cycle wants $414.00. Cannot imagine what a dealer would charge?????
Ride Safe All
I've got a 2014 RTL in the shop right now. Dealer wants to replace the rear caliper because they can't get the piston to retract. Very interested to see if there are any good solutions posted here soon.
2014 RTL Platinum
Seems to be a fairly common issue. Hoping to hear from someone that has figured out a solution.
Ride Safe All
Is it possible that the piston has expanded outside the caliper and the threads are no longer catching? Have you tried pressure on the piston while turning it to try and catch the treads.When you took the other Spyder to the shop a year ago what did they tell you was wrong? Or did they just replace the other caliper and call it good?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
pegasus1300, I suppose it has exceeded it,s travel and not catch threads, however as I turn the piston I also apply force to push in on the piston trying to "catch" a thread. the other Spyder, dealer just replaced the caliper and called it good, that person was fortunate, he was able to get it covered by his extended warranty.
Ride Safe All
Two thing to try.1 see if you can remove the rubber around the piston enough to see the threads as you try to re engage the threads. 2 if yiu have a good enough relationship with that other dealer ask the mechanic who did the work if was ever able to investigate and learn the real problem. There is a difference between a mechanic and a parts replacer.This could tell you what the real problem is and also what kind of a repairman he is mechanic or parts replacer. Other then that I have no other suggestions.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
I do not have a good relationship with the dealer, they do not and are not willing to give out too much info. My other problem with Spyder Dealers, I'm just over a 100 miles away from the nearest one. I'm going to try one more time tomorrow morning using a tip Joe Meyer gave me. I will report back with the results.
kent
Ride Safe All
What is the tool called, do you know?
Also, I saw a thread or post here where someone made their own, but didn't provide dimensions. I probably need to do that because I'd have to make a 90 mile trip to get this tool from Harbor Freight and I'm not going to do that.
Thanks.
2014 RTL Platinum
Does anyone have those dimensions? I'm probably going to have to make my own. Thanks.
2014 RTL Platinum
Thanks.
https://www.harborfreight.com/disc-b...-pc-63264.html
Then wait for a super coupon and its even cheaper. Or I use this on my car caliper and worked well.
https://www.harborfreight.com/push-p...ers-63700.html
Or there's another version that is square
https://www.lowes.com/pd/KD-Tools-Automotive-Disc-Brake-Piston-Tool/50190675?cm_mmc=SCE_BINGPLA_ONLY-_-ToolsAndHardware-_-SosHandTools-_-50190675:KD_Tools&CAWELAID=&kpid=50190675&CAGPSPN= pla{ifdyn:dyn}&k_clickID=7fc37dde-74bb-47c4-ac56-63008146388c&msclkid=c0fa117b71911453740d4a3b9b64c efd
https://www.homedepot.com/p/Lisle-Di...-207011085-_-N
brembo brake piston turning tool
Originally Posted by Joerolwing
I started with two fender washers with. 3/8" hole, glued them together, clamped them in a mandrel mounted in a drill press, and used a angle grInder to reduce the diameter to 1 3/8". I then squared the center hole to 3/8", then drilled and tapped holes for 1/8" 1/4" long screws, each 3/8" from center on the same line drawn through the center. Next, using a 1 1/2" long 1/2" bolt, I filed the end to a 3/8" square, possibly a fraction oversized. I then cut a 1" wide, 1/8" thick angle bracket from Home Depot and cut it in half at the angle. Next, I drilled and tapped it for the 1/2" bolt. Thread the bolt through this plate then press the bolt end into the washers, making certain the two "pins" are pointing opposite the bolt.
