Results 1 to 5 of 5
    May 2017
    Tulsa
    Default 2014 RSS SM5 no clutch resistance
    I have a 2014 RSS SM5 With no clutch resistance. When I pull to shift out of neutral there is nothing there and I cannot shift from neutral. Bike has sat in garage for 1 month but no fluid leaks noticed. I let the bike warm up in neutral but still nothing on the clutch level.
    Any ideas?
    Default Little checking.....
    For starters...check the fluid level by removing the cap ( put rags around to protect painted parts ). It may be empty or low so add fluid. Once you have done that bleed the slave cylinder (while your there pull the little black cover and check for leaks) you may also have to bleed the brake calipers as well. If this is a bit much you may have to see the dealer...
    The little black cover mine was leaking but no drips. If you see this you will need to replace the o rings on the piston...sorry the pics are sideways...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2009
    West Oz
    Dunno about bleeding brakes as well Cupcake? But OP may well need a special tool to undo that nut if the slave cyl is leaking - to be done strictly by the book or you will have a bigger problem.
    Default No special tools....
    But you do have to hold the center allen when loosening the nut. If not you will damage the diaphram that operates the vaccum assit to the clutch. I do recommend a shop manual whenever going into the spyder beyond oil changes etc....
    ​2012 RS sm5
    Dec 2009
    West Oz
