TricLED bumpskid LED kit; where to find harness connector?
The connection wire on this is only 24", which isn't long enough to bring it up to the harness connector for the running light at the headlight. Before I cut off the harness adapter and just use splice connectors, does anyone know where there might be a 12v line (switched) with a 2-prong harness plug close enough to the bump skid I could use it as intended? Thanks.
2014 RTL Platinum
Pete, Can it be that TricLED screwed up that badly, or am I missing something essential? Have you contacted them to discuss your problem?
I'm waiting for a call-back.
2014 RTL Platinum
That harness is ment to plug into the connector on the a arm that feeds your fender lights.
Easy peasy it's a switched circuit.
Hope that helps you, Gary
Originally Posted by gdjbear
That harness is ment to plug into the connector on the a arm that feeds your fender lights. Easy peasy it's a switched circuit. Hope that helps you, Gary
Hi Gary, yes it does. Now I just have to find that connector. Probably in toward the engine?
2014 RTL Platinum
Under the A Arm about 6 inches from the fender on the bottom of the plastic covers for the A ARM
That's where you will find those connectors
MAy have to cut a wire tie or two to get at the connector easier
Originally Posted by trikermutha
Under the A Arm about 6 inches from the fender on the bottom of the plastic covers for the A ARM That's where you will find those connectors. MAy have to cut a wire tie or two to get at the connector easier
Thanks. That's great info. I'm surprised TricLED didn't mention that in their D-I-Y instructions.
2014 RTL Platinum
That's how I hooked up my fender lights too
Easy peesie too plug and play
