Results 1 to 25 of 34
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Default FOBO TPMS Custom images
    Hey all, been getting a lot of requests for my custom FOBO images.
    I guess my original post is down the list somwhere.
    Anyway here is a link to a ZIP file with all of the custom images I have made so far.
    RS, ST, RT, F3's and many colors. Also some Slingshot images.
    https://drive.google.com/open?id=0B9...DE0T2tGRVNuWTQ
    Enjoy,
    Bob
    2011 RT-S SM5 - Black
    Active Member Spiceman64's Avatar
    Las Vegas, NV
    Default Silver - looks like asphalt gray :)!
    Thanks Bob! I'm getting a FOBO for Christmas so this will be a great add. The silver RT image is certainly close enough!
    Todd
    2017 RTL Asphalt Gray
    Squared Away Laser Alignment
    TricLED:
    - Safety LED Package #1 w/Blinker Module
    - Mirror Turn Signals
    - RT Wide-Vu mirror
    - LED Headlights/Foglights
    - Large USA Flag LED w/Mount
    - Foam Hand Grips
    FOBO TPMS
    Custom Dynamics HMT LED Brake Light/Magic Strobes Brake Light Flasher
    SpyderPops BumpSkid
    BajaRon Anti-Sway Bar
    Pitbull Primary Muffler Replacement Pipe
    Lamonster Big City Thunder QQ Monster Baffle
    Roadster Renovations Vibration Damper Kit #3
    Feb 2012
    Spring City,Utah
    when I go to the file and then try to open one of the images nothing happens for me.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    NorCal - Northbay
    Be sure your computer can handle zip files (winzip etc) and it would be best to export any image you want to look at or use first, since they are in a zip file. Right click on the one(s) you want and choose the export option. Take note of where you choose to save them then open them from there. You then need to get them on your phone or tablet wherever you are running fobo if you aren't downloading directly. In the fobo app you need to press and hold on the image of the sypder on the screen that has the pressures. It will give you the option to change the bike photo. Then navigate to where you have the pic and select it.
    OP, one thing I have noticed is that the pics are too large to be scaled properly in the fobo app.... it ends up cutting off a good portion when importing.
    Chuck
    May 2013
    Stanton, ca
    Quote Originally Posted by hypurone View Post
    You have to be doing something wrong then. Many many people have used these with no scaling issues and in fact they are made to be and fit exactly as the stock images.
    Eample:
    Active Member jcaburto's Avatar
    Jan 2017
    Whittier, Ca
    I found the same problem when applying it to my iphone. I had to resize the "paper" or background to 11x13.9in and that took care of the problem.
    Thank you to the original poster for sharing. I didn't even know it was possible to customize that image.
    Julio Aburto
    Black Currant 2013 Can-Am Spyder RT Limited
    2013 RTL , Black Currant
    May 2013
    Stanton, ca
    Hmmmm I wonder if this is a new problem maybe with the iOS 11.
    I am still on 10.2 myself and no scaling is needed. Fobo did it automatically.
    Can you give me more details. What iOS version are you on?
    Can you show me what it looks like if you do not scale the image?
    Bob
    NorCal - Northbay
    Quote Originally Posted by finless View Post
    Eample:
    More likely has to do with me using an Android vs iphone....
    Chuck
    Jan 2017
    Whittier, Ca
    I'm on IOS 11.1.2
    This is how the image will get cropped unless I manually add more background to it using an image editor in my computer.
    Julio Aburto
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Quote Originally Posted by jcaburto View Post
    I'm on IOS 11.1.2
    mine is the same way , can u adjust it right on the iPhone ? I have a 7 , please advise
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    May 2013
    Stanton, ca
    OK you are losing the transparent backgroud!
    How are you transfering it to your phone? You cannot open it in any kind of picture editor, etc as you lose the transparent background.
    Some programs that transfer the image to your phone will convert it. Do not use them.
    Finally even when you preserve the transparent background, the image will be large until you click USE on the screen. Fobo will then scale it like the picture I show in the above post.
    Read this original post. It explains it and you can also see other peoples posts on how they transfered it to thier phone for Android.
    http://www.spyderlovers.com/forums/s...image-for-FOBO
    Bob
    Oct 2015
    Iowa
    Bob
    Bob, sorry to be a pain
    I saved it to the phone in a file, then open and save image. It looks exactly like the screen that was posted but when you hit use the background is transparent, I can move the square around so I can get the whole front end in but it still cuts off the back. any other ideas. I've ran it thru other computers and such with no luck. Im trying to do RT- white
    any suggestions
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    May 2013
    Stanton, ca
    The image you posted shows a black background. that means it lost it's transparency. Are you no longer getting that? e.g. you can see the pressure readings around the spyder image?
    Are you Android or iPhone?
    Bob
    Oct 2015
    Iowa
    Default fobo image
    Bob
    When i put it on my fobo it is transparent , I can see everything. iphone 7. When I bring it up, it has the square around it which i can move to cut off more of the back or the front....I'll show you exactly what my screen looks like .......please hold
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Oct 2015
    Iowa
    Default here you go
    Finless,
    This is what i got, notice back cut off and the two white lines to the left (border of image)
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Bob,
    Thanks for bringing this back around to my attention.
    Now that I've had to buy a Smartphone: the TPMS is back on the list!
    Jan 2017
    Whittier, Ca
    Bob
    Bob,
    The black background is the way the computer or device tells you that the GIF file you are using has a transparent background.
    I'm on iphone 7 too and the image gets cut off to a square by FOBO. Your images are not square, they are rectangular.
    GIF files can be edited using image editors such as Photoshop or in my case CorelDraw or CorelPhoto. All there is to do is change the size of the background to a perfect square (see screenshot attached) and then save the file as a GIF with transparency again. Don't flatten it or save it as a JPG so you won't loose your transparent background.
    Julio Aburto
    May 2013
    Stanton, ca
    Bob,
    Yes I know the editors as those are what I used to make the images and transparent background GIF. Photoshop. Up until recently FOBO handled them as rectangles and properly scaled them with NO cut off. Phones screens are a rectangle. This is the first I have heard of this new problem. In fact what is odd is a Spyder owner I know just used one on his iPhone 6S+ iOS 11.1.2 no problem (at least he said). Something is amiss.
    This is my iPhone 6+ on iOS 10.2 (I am staying on 10.2 now for a reason).
    As you see same images no cut off. I am on the latest version of FOBO. So it appears this maybe an iOS 11 thing.
    May 2013
    Stanton, ca
    OK BINGO! FOBO changed how it works.
    So I had my image set long ago and have not changed it in a long time. When upgrading the FOBO APP the image stayed OK and not cut off. So I decided to load one of my other images just now. BINGO I see it. There is now a box to move the image around in before you click "use".
    So FOBO changed how this works... People that had older version and upgraded had no problem as the older version scaled it. This new version does not work the same and thus problem.
    In fact I think this is BUG because if you notice you can PINCH the image with 2 fingers and resize it to fit in the box. THAT does not work as when you LET GO it re-enlarges. So they have bug in their PINCH TO SCALE on that screen. You should be able to scale it to fit in the box. Try it and see..
    OK I have some work to do and fix all the images I made (like 20 of them).
    Stay tuned I will fix them all and update the download. Give me a few days to get the time.
    Oh and THANK you for finding the problem. I was going nuts there for a while wondering WTH.....
    Bob
    May 2013
    Stanton, ca
    LOL I found work around but even this has a BUG! You need 3 fingers.
    So use 2 fingers and pinch the image to make it smaller and fit in the box. Then using a 3rd finger while HOLDING the pinch to fit in the box, tap the "use".
    This works but the scaling is whacked out. The Spyder looks pudgy...
    I am going to contact FOBO about this issue as it use to work properly. They have always been good about fixing things. This will save me from having to redo all the images I made. Also if they fix it later, now the images I redid my break again and I would have to fix them yet again.
    I hate bugs!
    Bob
    May 2013
    Stanton, ca
    By the way. All these images I made long ago were scaled and sized to the same size as the STOCK FOBO images they used at the time (I ripped them from the .ipa file). So they broke the software.
    Bob
    May 2013
    Stanton, ca
    Last thing... Can someone on Android tell me if this same problem exists? Per my above post about pinching to fit in the box?
    Thanks,
    Bob
    Jan 2017
    Whittier, Ca
    The three finger pinching worked perfectly on my iphone.
    Julio Aburto
    May 2013
    Stanton, ca
    Yea but if you look close, the image looks pudgy... e.g. length is reduced more than width.
    Bob
    Oct 2015
    Iowa
    Default fobo
    Bob
    i got mine to work. I ran the image thru Corel photo , saved background as square and no issues . Worked perfect , I also cleaned up a line that appeared on the edge .
    Thanks Bob and others for all the pointers
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
