PARKING BRAKE QUESTION
I’m getting ready to replace my rear brake pads soon. I have watched the video from greatrides and it looks pretty easy. But something the video didn’t address is whether the parking brake should be off before I begin?
2020 F3 Ltd
Spyderpops Bumpskid
PARKING BRAKE
Absolutely !!! .... because if it's on the calipers are squeezing the pads against the rotor ..... you won't be able to get the caliper off ... when you stop the engine, it will beep for about 30 seconds +/- ....then start your brake job ..... Mike
...and don't forget.....
..... to unscrew (screw bach to open the space to insert the pads) the piston. Otherwise, the pads won't fit in or the pads/caliper assembly won't fit over the disk.....
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
REAR BRAKE PADS
Duly noted. Thanks Mike and Richard!
2020 F3 Ltd
Spyderpops Bumpskid
