Results 1 to 4 of 4
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Default PARKING BRAKE QUESTION
    ​I’m getting ready to replace my rear brake pads soon. I have watched the video from greatrides and it looks pretty easy. But something the video didn’t address is whether the parking brake should be off before I begin?
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Quote Originally Posted by JKMSPYDER View Post
    Absolutely !!! .... because if it's on the calipers are squeezing the pads against the rotor ..... you won't be able to get the caliper off ... when you stop the engine, it will beep for about 30 seconds +/- ....then start your brake job ..... Mike
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default ...and don't forget.....
    ..... to unscrew (screw bach to open the space to insert the pads) the piston. Otherwise, the pads won't fit in or the pads/caliper assembly won't fit over the disk.....
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Dec 2012
    Murphy, NC
    Default REAR BRAKE PADS
    ​Duly noted. Thanks Mike and Richard!
    2020 F3 Ltd
    Spyderpops Bumpskid
