CARDO SCALA G9
is there anyone out there that uses the CARDO SCALA G9 Head-Set unit.....?
if so.... do you have a cure for LOW VOLUME....? mine is OK @ FULL volume until i get to about 30 mph... after which the wind noise absolutely drowns out either the music or conversations that are going on...
i've seen videos of replacing the speakers with larger ones, but i hate to do that... any help would be greatly appreciated...
PS; Scala reps DO NOT answer my emails when requesting an answer....
thx in advance...
Dan P
SPYD3R
Try this
You used to be able to go online and update your units. I have the G9's but don't have a volume issue and do have noisey helmets. Use mostly Mp3 player and the intercom. Phone also works great. I have not upgraded but should do it online.... is your source volume up...? if my Mp3 volume is down the scala is not loud....
2012 RS sm5
thx in advance...
Dan P
SPYD3R
Make sure your speaker placement is correct. it they are not right at your ears it is hard to hear.
2015 F3s White
BRP Drivers and Passenger backrest
Blue Ridge windshield
Corbin Saddle Bags
Make sure you have the latest firmware and check your settings
2015 F3S SE6
You don't stop riding because you get old, you get old because you stop riding
They have a jack on the bottom for ear buds. Using those instead of the speakers will give you more volume than you need.
2014 RTS , Spyderpops oversized brake pedal Cognac
THX
THX all....
i've gone into the software and updated many times... no luck...
i've made certain my speakers are exactly where they should be... no luck...
where is the 'jack' for the ear buds...? i don't see one...
Dan P
SPYD3R
