Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Apr 2017
    North Central Florida
    Quote Originally Posted by Ramg66 View Post
    my Tundra on the other hand has been blinking charging for 2 days, I even swapped the BT's to troubleshoot and still same thing, why is that?
    Well the Tundra has a MUCH larger battery so...............
    Leave it connected for a couple of more days.
    If it STILL doesn't indicate fully charged, then it's time to get that battery tested. Likely it is about done for.
  2. #27
    Apr 2017
    Quote Originally Posted by R FUN View Post
    I did not join this discussion to argue, I am just telling you my experience , I do not have shares in HF.
    Roger
    Good. Someone else relating an experience or opinion that is different than yours is not an argument.......unless you turn it into one.
  3. #28
    Dec 2015
    Oakley Utah
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    don't confuse the fact with made in china, it's how well made or who makes it not necessarily where. corvette & escalade oem chrome wheels are made in china under gm. but made in china under harbor freight is where i have a problem. harbor freight are very cheap items, when occasionally used are ok, but when used regularly they will fail and electronic items from them will not be accurate. i always say if you buy cheap chinese you will get it.
    That's what they used to say about 'made in Japan'.
    2014 RTL Platinum
  4. #29
    Nov 2017
    Gaithersburg, MD
    Default Battery tender/charger
    Hello, I found a Battery Tender 3 amp at Steelz (Costco outlet) for $30. I purchased thinking I would ask here if it was too much for my Spyder, if it is I will end up using for my truck. I have been doing research and hear a lot about the junior and plus. I think I read a post one time saying the plus was better for newer batteries. Any advice is appreciated.
    Thanks
    Ramg66
    I have a CTEK 7002, which takes care of my Honda Pilot (2012), Wrangler Unlimited (2015) and my new Magnesium Gray Spyder (2017 RTL SE6). CTEK is a workhorse.
    Hope this helps.
  5. #30
    Very Active Member Star Cruiser's Avatar
    Jan 2008
    Wasaga Beach, Ontario
    Default Where are the terminals?
    I had a 2012 RT-S and put on a trickle charge for 24 - 48 hours every month or so during the winter to keep things ready for Spring.
    Well, I went to do it on my 2016 and it does not seem to have the same set up. Where do I find the terminals on a 2016 RT-S? I've looked under the seat assuming it would be the same as 2012 RT-S
  6. #31
    Apr 2017
    Refer to your owner's manual.
    The new RTs have the battery up front and it is easily accessible through the frunk.
  7. #32
    May 2017
    Mesa, Arid-Zone-A
    I ride 2-3 days each week so no need for a battery maintainer. To each his own.....
    Semper Fi
  8. #33
    Sep 2017
    INDIANA, USA
    Default Battery Tender
    Most things have: a good, a Better, OR a GREAT. Just Be careful and Buy Wise.
    ENJOY YOUR LIFE WITH A SPYDER
