Results 1 to 7 of 7
    Nov 2017
    GA
    Default Juice box on 2008 Spyder rs
    Recently bought 2008 Spyder with 11,400 miles. Runs poorly from idle to 3000/3200. Changed the Two Brothers exhaust(too loud) to stock from 2015 RT. Did not affect poor running. Took side panel off and found Juice Box. Number one shows green, number eight shows flashing blue when in 50 MPH range. I have no instructions as all. Checked small tubes on side of throttle body, they are fine. I do not suspect plugs or wires at this low mileage. Surges a little at steady 50/60 MPH but pulls strong at full throttle.
    How do I go about trying to program juicebox?
    Harold Knobel, I'd rather be autocrossing, DM
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Most juice boxes that I have used have a straw in plastic stuck to the side.
    1. Remove the straw
    2. Unwrap the straw
    3. Use pointed end of straw to poke through the small hole on the box of the box.
    4. Place lips tightly around the other end of straw and suck to enjoy the fruity goodness.
    Sorry I could not help myself, I need five more posts for 1,000.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Default Not sure
    If you went back to stock on the exhaust just get rid of the juice box it does you no good. I never used them on any exhaust I have used. As for the vaccum hoses did you check them well..?? They are tricky and change with heat and throttle response...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2016
    Tombstone Az
    The juice box was a lot of problems on the 08's. Read a lot of threads on the problems with them. Did not add mufflers or JB on mine. I kept it stock. No problems or issues.
    Hindle exhaust system was also problematic for most.
    Sep 2016
    clark county indiana
    Default a whaaaattt ?
    so I am guessing the " juice box " isn`t but rather ---> a vacuum type canister for gas fumes from exhaust ?
    Sep 2016
    Default if your cycle
    now you bought the cycle , had it been sitting a while ? bad gas ? or maybe the vacuum hoses are egged on the ends like mine were on a 2012 IMG_20171111_135739.jpgIMG_20171111_135824.jpgmy cycle ran rough at idle --- changed the hoses , and drained the gas , ( which I bought at an out of the way country store , which might have been bad from the tanks --- runs great again )
