Results 1 to 13 of 13
    Dec 2015
    Oakley Utah
    Default OEM fuse block fuse to change accessory power to nonswitched
    Okay, I've looked around but can't find what I'm looking for. Somewhere I saw a reference to a fuse on the fuse block for the accessory circuit and how it can be moved to make it a nonswitched circuit (i.e. always on). I want to make my wife's bike accessory circuit switched so as not to cause battery drain (a previous owner apparently wanted just the opposite).
    Which fuse block and fuse is it and how can I tell which position it is in? Thanks.
    2014 RTL Platinum
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    Are you talking about the 12V accessory port? On my 2017 RTS it's the RH Fuse Block. If the Fuse6 is installed the 12V power outlet is only operational when ignition is ON. If Fuse7 is installed, then 12V power outlet is operational all the time. I switched mine to Fuse7 installed so I can use the battery tender thru the 12V outlet. P. 60 of the manual.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by HankD View Post
    That's it! Thanks.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Took some pics for the benefit of other forum readers with the same question
    20171128_125144.jpg choose right fusebox (on the left in photo)
    20171128_125523.jpg open the cover and you'll see this other cover
    20171128_125415.jpg ignore the black numbering; they are numbered left to right 1,2,3 ... 6,7 (#8 left blank)
    extra replacement fuses are in the fusebox cover
    to have trunk accessory plug constant 'on', move 5A fuse from position #6 to #7
    2014 RTL Platinum
    Jul 2011
    Mitchell, Ontario, Canada
    Default Owners manual
    This is covered by the owners manual.
    Page 150 from the 2014 RT manual.
    Dec 2015
    Oakley Utah
    This is covered by the owners manual. Page 150 from the 2014 RT manual.
    You are correct. Sometimes I have access to the internet but my manual isn't handy.
    2014 RTL Platinum
    Jul 2011
    No need to get out the paper manual. A digital copy is available on brps web site free. It can be downloaded onto every smart device you wish.
    Dec 2015
    Oakley Utah
    Good to know. Do you have a link for that?
    2014 RTL Platinum
    Jul 2011
    http://www.operatorsguides.brp.com/I...8-3f929676334a
    Dec 2015
    Oakley Utah
    That's great. Thanks!
    2014 RTL Platinum
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Pete,
    Re: choose right fusebox
    I know that my '08 is quite a bit different than your model. But, I used a non-in-use fuse holder for my driving lites ( see details in my write-up ).
    They come on when the key is turned on; even before the engine is started.
    What took some time to get used to ( and unnerved me at first ) is that they stay on for about 15-30 seconds after I turn the key off.
    I do not know if the fuse that you choose to use will do this; but, be prepared for it.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Apr 2015
    Green Bay, WI
    My low end cost battery tender goes straight to the battery via the frunk to battery connector with an inline fuse. Open the frunk--plug it in--close the frunk--not tight but close. real basic-easy & fused. Accessory power for the radio--I tapped into the headlight lead.
    Darrell
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Video
    Here's a video from Pierre:
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
