Results 1 to 9 of 9
Thread: Driver backrest
    Nov 2017
    Gaithersburg, MD
    Default Driver backrest
    Hi
    can anyone please tell me how to install the driver backrest Ultimate Seat Product Code: 14610 in 2017 RT Spyder Limited?
    How to pop up the slot?
    Thanks and I appreciate the response.
    Best,
    BriteSpydie
    Default your issue
    Quote Originally Posted by BriteSpydie View Post
    Hi
    Best,
    BriteSpydie
    The cover is EXTREMELY DIFFICULT to get off ...... I have done quite a few and I wondered if BRP ever wanted it re-moved ....which doesn't make any sense but .... You don't have to cut it ..... it is a separate piece .. Mike
    Nov 2017
    Gaithersburg, MD
    Default Thank you
    Thanks or the response.
    Can you please let me know how to separate the piece?
    Nov 2017
    Gaithersburg, MD
    [QUOTE=BLUEKNIGHT911;1319001]The cover is EXTREMELY DIFF]ICULT to get off ...... I have done quite a few and I wondered if BRP ever wanted it re-moved ....which doesn't make any sense but .... You don't have to cut it ..... it is a separate piece .. Mike [/QUOTE
    Nov 2017
    Gaithersburg, MD
    Default Thanks
    [QUOTE=BriteSpydie;1319011]
    Thanks
    Sep 2014
    USA
    I think your asking how to install and remove the Ultimate seat driver backrest from the seat?
    To install line up slot and pushuntil the ball gets seated or clicks., to remove push down then pull up quickly. May take a few tries to get out but not to bad.
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2017
    Gaithersburg, MD
    Thanks. What I wanted to know is how to remove the piece of plastic on the seat to insert the driver backrest? It is not popping out or cannot be pulled out easily.
    Sep 2014
    USA
    Contact Ultimate Seats they should help. Not sure what plastic piece needs to be removed??
