Results 1 to 6 of 6
    Member Chappy KC's Avatar
    Oct 2017
    Delaware, Ohio
    Default SE6 CLUTCH PLATES
    I notice that the SE5 on the 998 motor is better off running 4000 rpm and up because it allows the clutch plates to fully engage. Is this the same for the SE6 on the 1330?
    2017 RT-S. Bone Stock!
    Nov 2012
    North Las Vegas, NV
    No the clutch on the SE6 is hydraulically activated.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default No....
    The 1330 engine got the 6 speed transmission and the hydraulic clutch set up and run at a lower rpm as well. You no longer have to worry about the rpms when ryding models with the SE6 transmissions.... still lugging the engine is not a good thing.....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    The 998 had a centrifugal clutch and RPMs needed to be maintained to prevent clutch slippage. the 1330 has a hydraulic clutch. this is the reason I moved from to the 1330. No worries about clutch and RPM.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Default CLUTCH
    ..... However I can't see how an SE - transmission can be LUGGED .... If the revs or power requirements require more input .... the transmission is designed to Downshift, to accommodate this ..... Only the Manual could be lugged ...............Mike
    Jun 2010
    Las Vegas
    [QUOTE=BLUEKNIGHT911;131884.... Only the Manual could be lugged ...............Mike [/
    And that’s hard to do.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
