How Fast
How fast has anyone had their RT ? Looking to find out what the top speed is . Just curious .
Don't know how fast because my eyes were watering so much I could not read the speedometer. But people who saw me said I was leaving a "vapor
trail" Go figure!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
hahahahaa
110
So far the only opportunity that I had to open her up got me to 110 mph. She still had a little bit more to go. Maybe 120-125? I'll let you know next spring.
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
110 (per GPS) and still more to go before we ran out of straight road.
I had my wife's 2014 RTS up to 107 mph and still pulling until I ran up on traffic
and had to back off.
I had my 2016 F3 T up to 115 and still pulling hard until I backed off.
Toby
2020 RTL
RT-S PE#0412
A few years ago a few of us on 5 bikes (2014 RT LTD, 2014 STL, 2013 STL, 2012 RT-S, & 2011 RT) did 3 laps around the Pocono Speedway full out. The best speed if I can remember correctly was about 187 kph which is about 116 mph. We had them pegged chasing the pace car. A once in a lifetime moment.
My 2011 RTS is absolutely silent because it goes faster than the speed of sound.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Well....
I have been upto 117 mph on my RS but ran outta road... still had some left in her but you are limited to what the rev limiter will let you do. I believe that they are set to about 120 and the highest believable speed I have seen is 126 mph. Get rid of the limiter and who knows....
2012 RS sm5
I have had 2014 RTS up to 70mph.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Had mine up to low 80's. Have no need to go faster. Life is short enough.
I touched 113 with a slight down hill and my windshield as low as she goes, and no, I don't recall my tire air pressure
Grandpa Pete
Peter & Kim Pontinen
2020 RTL Dark Marsala
Ozzie Ozzie Ozzie
I know some of you over there have questioned the need for the large numbers at the top end of the speedo dial, but for those of us who use kilometres instead of miles, even stock the 200 plus speedo is just sufficient - there are vids showing V-twin powered Spyders getting up to speeds over 215kph on the autobahn & elsewhere, so for the pre-2014 models with AU/EU gearing, 130 odd mph IS achievable, even if most of us don't ever want or need to push our Spyders to go quite that fast too often!
That is, at least until you get one of the better ECU upgrades out there, like the ECU upgrade done by Jase (I am rapt with my upgrade, but if you want to talk more about it, PM me or contact Jase; he is here in Aus, but is a member here with that username & is otherwise found at rotaxracing@gmail.com) Suffice to say that his upgrade removes a lot of the detuning & restrictions/limitations imposed that stop these engines running out to the very same output levels that they safely achieve elsewhere/on other machines - it's an upgrade that makes running the speedo off the dial well & truly achievable!! And while the std performance with stock settings is OK for most, after the rotaxracing ECU upgrade, the performance you have on tap (even if you don't necessarily want to use it in getting up beyond the numbers on the speedo dial ALL the time) is nothing short of fanbloodytastic!
And when I'm not playing with all the extra GO, my 'sensible ryding touring range' is significantly increased too!! It's awful hard to resist the urge to play tho!!
Reason: 'Our'
2013 RT Ltd Pearl White
Ryde More, Worry Less!
I would be happy to see 40. 40 miles per gallon that is.
I've had my 2012 998 VTwin up to 95 to pass but I don't think it has much left after that.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Originally Posted by akspyderman
The subject has been discussed a few times over the years. The number that comes up mostly is the 110 - 115 miles per hour range. This information based on what people read from their speedometers while tooling down the highway.
There are a few that have documented speeds--as in from racetrack tryouts. They will probably show up.
Me?--90 - 95 maybe once. Have not tried the limits. The 225--that's in the ball park in you have your speedo set to KPH. I used that feature while driving in Canada--makes it easier to follow the speed limit signs. 62 MPH is equal to 100 KPH. I did 120 when in Canada a couple times.
A good trick to play on a novice rider. Put in in KPH and go for a ride on the highway at about 70. It will show up on the speedo as plus 100. That usually gets their attention.
In my previous life I used to travel to Canada for work and always loved doing it.
On the bridge crossing over I would change to KPH, this was great because I could legally drive much faster than I could in the USA almost twice as fast, 100 vs. 65.
The other pleasure was the fact that the fuel was much less expensive, about $1.27 or so vs. $2.50. That was awesome.
I could drive almost twice as fast and fuel was almost 1/2 price.
Now, before you say ANYTHING, I live in my own little world, don't ruin it for me!
Joe
U.S. Army Viet Nam Era Vet
Utopia Deluxe driver backrest
LED fender lighting
Fast Flash LED brake light
Spyder Pops LED/skid plate
Joe
You have it figured out nicely. Mind if I join you.
100 even on my ST-S, but that was only to see how fast everyone else was blowing past me. Even at that, I was barely overtaking them..........
Joe
Wouldn't dream of it. Might visit you there on occasion.
~Sandee~
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
109 on a race track out here.
Bob
2011 RT-S SM5 - Black
