Need rear tire balanced!
Guys I replaced my back tire this week but cannot find anybody (including area dealerships!) who can re-balance it! Either they can't fit it on the shaft of their balance machine, their machine is broken and they don't know when it will be fixed, or they just don't have a machine.. or in the case of Kingwood Harley dealership they have a balance machine that can do it but won't because it's not off a Harley motorcycle (which I find a bit offensive frankly but oh well).
Anybody got suggestions? I'm in the Humble/Conroe/Livingston triangle.
Thanks!
- Michael
Thanks!
- Michael
Car tyre or Kenda, Michael? Most car tyres these days don’t need balancing as long as the tyre shop has mounted the tyre dot alongside the valve.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
My old rear Kenda came off with a bazillion weights on the wheel. New car tire has none but I did have a centramatic balancer installed. No need to ever balance rear wheel again
Semper Fi
If you have two jack stands, put the axle through the wheel and put it between the stands. Get some stick on weights at an auto parts store. Heavy spot will be down after a spin. Tape weights on the opposite side until you can stop the wheel in any spot without it moving.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
This!
Chuck
I used balance beads in the rear tire 4 ounces. They work great. I am going to put them in the front tires also 2 ounces each. The only problem I had was getting them. I had to have one side of the tire open up and poured them in.
Thanks!
- Michael
that's because they don't want to add to anything on the road that can out perform a Harley; which is pretty much anything.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
Originally Posted by Highwayman2013
I've spoke to several people who are using these dyna beads & they are all happy using the product. My Rear Kendra has 1/2 dozen tape weights on it. Any static wheel balancer would work just fine also. Hunter Equipment wheel balancer with "Smart Weight Feature" proved that horizontal balance isn't usually necessary thus a static bubble balancer at any old small shop uses would work. I've had 2 Harley's 2003(oil pump gear broke off at 50 mph) & a 2014 & my Suzuki's & Yamaha were superior.
Darrell
Thanks!
- Michael
PM me. I think we can help you with this.
Michael211_2000, I followed BLUEKNIGHT911 (Mike)'s advice, had my new (Car) tire mounted on the rear rim, no balancer, no weights, (removed all the old weights too) and I couldn't feel any vibes whilst riding. My waterbottle on my handlebar cup holder barely jiggles at all, at any speed. (I do have the Lamonster centramatic balancers on the front wheels) though the wheels also have no balancing weights.
I've driven 8,000 miles on that rear tire this last year, you couldn't tell looking at it.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
