Results 1 to 8 of 8
    Apr 2017
    corpus christi, texas
    Default Fox shock adjustment
    Where can I buy the correct size wrench to loosen and tighten the nuts on the Fox shocks?
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by donrokon View Post
    If you're referring to the mounting bolts-------& you don't have a set of wrenches or sockets--your best be may be an adjustable Craftsman type wrench. If you had a $12 micrometer from Harbor Freight You could measure the net head. If you plan on doing more mechanical things you may want to purchase a low cost set of SAE & Metric wrenches & socket sets. Most skilled mechanical people might not agree with the adjustable wrench--but if it fits & it's seldom used---It works just fine.
    Good Luck,
    Darrell
    Apr 2017
    Quote Originally Posted by Wildrice View Post
    If you're referring to Nohe mounting bolts-------& you don't have a set of wrenches or sockets--your best be may be an adjustable Craftsman type wrench. If you had a $12 micrometer from Harbor Freight You could measure the net head. If you plan on doing more mechanical things you may want to purchase a low cost set of SAE & Metric wrenches & socket sets. Most skilled mechanical people might not agree with the adjustable wrench--but if it fits & it's seldom used---It works just fine.
    Good Luck,
    Darrell
    No , i mean the two nuts that hold the spring in the proper preload position. Thank u.
    Default Tough one....
    they call them spanner wrenches and they come in many sizes and styles. I have accumulated a large assortment from many brands of bikes and still don't have a decent fitting one. I would try Fox and see if they offer them. In a bind I use some large channelocks...google fox shock spanners... and you will see many...
    ​2012 RS sm5
    Jun 2010
    Ontario, Canada
    Any snowmobile place will sell the correct size. You also can make your own, not hard to do. Also you will be able to turn by hand as long as all weight is off front end of spyder and lock ring is backed off. The lock ring just tap with flat screwdriver to break the lock against the adjuster ring then back off by hand.
    Apr 2015
    Green Bay, WI
    Harbor Freight have several sizes--all are flimsy & can bent if not held straight.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    And be prepared for a battle of strength! I tried to adjust mine new ones and they wouldn't budge, not even with a punch and hammer! The powder coat basically "glues" them together....
    Chuck
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by hypurone View Post
    I solve lots of problems with large channel locks--even removing tight oil filters. If there's access room. I imagine a butane or propane small torch might damage the seals while freeing the powder coating?
    D
