Results 1 to 4 of 4
    Apr 2015
    Green Bay, WI
    Default K&N CM-1314 Replacement Air Filter for F3's
    Opinions requested---did the K & N Air filter make any difference versus the stock air filter??
    Darrell
    Default Always do....
    On all my machines... but then I dumped the Airbox and went with JT's still with the K&N and ram air and got even more...and then....the pipe, plugs, wires etc...
    ​2012 RS sm5
    Default K & N FILTER
    Quote Originally Posted by Wildrice View Post
    Darrell
    I have used them in to many veh's to count .... and I like them, but IMHO I don't think any gain would be noticible .... the computers in the Spyders make adjustments to almost EVERYTHING you change.... I used them for EASE of maintenance and saving money ............ Mike
    Apr 2017
    Boulder City
    Example if you use a replacement K&N on my Polaris Razor 1000 it’s guaranteed to suck in dust and void the warranty.... bad idea😳. The OEM paper filter is superior in filtration and the volume of airflow at wot is more than sufficient for stock Spyder( proposed turbo would require larger filtration surface) . I only use K&N on my Razor as a prefilter to my OEM paper filter😎
