Results 1 to 4 of 4
    Mar 2013
    Mount Vernon,MO
    Default Bulb replacement
    As you sit on the RT, I have a right hand headlight out, and a left side fog light out. Can someone walk me through replacing the bulbs?
    Are the bulbs standard replacement bulbs I can acquire at my local auto parts store?
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Searach??
    Hello Cindy,
    If you search there are a few threads/ videos on changing out the headlights/ fogs. The headlights and the rt. fogs aren't too bad. THe left side fog is harder and frustrating at times but I did change them all to LEDs ( HIGHLY RECOMENDED ).
    You can get replacement bulbs at auto parts stores.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2014
    USA
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Quote Originally Posted by Cindi View Post
    You have not stated which year model your RT is
    Ref the Fog lights
    All the videos I could find were for pre 2014 RT’s they are easier to get access than the later RT’s esp on the LHS as the air intake gets in the way
    I found the easier way was by removing the Front funk
    Videos for headlight bulb replace is the same for all model years of the RT
    see this thread
    http://www.spyderlovers.com/forums/s...-Bulb-2014-RTS
    Hope this helps
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
