Results 1 to 22 of 22
    Sep 2017
    Fort Mill, SC
    Default 2015 RT LTD with 1 piece rear wheel - Change bearings
    Has anyone had to change the bearings on a 1 piece rear wheel with the tube between the 2 bearings tight up against the bearings on both sides? If so, how did you do it?
    Idaho
    Quote Originally Posted by jpcoder View Post
    Are you saying the hub is not bolted to the wheel? It it's a stock wheel the wheel and hub are two pieces bolted together. Unbolt the hub and the spacer will fall out.
    2014 Copper RTS
    Sep 2017
    Fort Mill, SC
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Wow!! A one piece hub! I wonder whose idea this was.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Nov 2015
    I just looked at the rear drive wheel for 2016 and 2017 on discounthondaparts and it doesn't show a 2 piece rear hub for those years.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    just like every other one piece hub with spacer, one bearing will have to be drifted out, then the spacer will fall out, and you can use a more conventional press if you want to take out the other one. Ensure you have your new bearings on hand before even starting this job.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Sep 2017
    Fort Mill, SC
    Quote Originally Posted by 4 MARIE View Post
    Tried it, no way to get between the bearing and the inner tube. Inner diameter of the tube same as bearing.
    Default Lets see....
    Third world method....take a long large flat blade screw driver or rod and pry the spacer to one side ( put the rod in one side just shy of the otherside bearing and pry right and or left till it moves may have to hammer a bit ) just enough to get a bite on the inner race and beat that bearing out the back side. the spacer will fall out and then you can remove the other bearing. Then re - install the new bearings with the spacer in place.
    ​2012 RS sm5
    Idaho
    Quote Originally Posted by SteveLaoyster View Post
    You are so correct! What I saw on the BRP parts page is the same parts diagram as you were looking at. Both show the hub just as in years past but in phantom lines with no part number. I missed that aspect of it when I was looking at the diagram.
    Changing from a 2 piece wheel to a one piece wheel is a change from 2014 to 2015 I don't think anyone on this forum has mentioned before.
    jp, it would be worth the $30 or so to download a copy of the RT service manual. There are a few places to get it but a good one is www.canammanuals.com. It will have the instructions on how to get the bearings out. Plus you'll eventually need it for all sorts of servicing and farkle add-ons later anyway.
    I think I figured it out. The parts diagram shows a circlip between the seal and bearing on the sprocket end of the hub. That indicates to me the bearing on that end is a non-interference fit. You should be able to work the bearing out with a screwdriver or some sort of an expanding puller that fits inside the bearing. Maybe something like a piece of hose on an all thread squeezed between two pairs of nuts and washers. Or an expanding plug you might find at your hardware store.
    Once you get that bearing out you can drive the other one out using a socket or something of the sort to push on the spacer, or reach through and push directly on the bearing.
    2014 Copper RTS
    Sep 2017
    Fort Mill, SC
    Thanks for the info on the service manual! The circlip is part of the sprocket and not part of the wheel. For the wheel, its bearing, inner tube, bearing. The issue is not being able to get any access to the back side of the bearings. The tube fits tightly into holes in the wheel that do not allow it to be moved side to side and it butts flush against both bearings with no slack.
    Mar 2013
    What you need is a blind hole bearing puller. A number of auto parts sellers will rent you one for low cost - if not for free. Once you get the old bearing out so that you have the tube you could then file, or cut notches in the tube to allow access for a standard bearing puller to grip the new bearing when it comes time to replace it. The tubes job is to lock the races of the two bearings so the small amount you would be removing will not affect that.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Quote Originally Posted by PW2013STL View Post
    This is correct per the service manual. You need a complete set, which also includes the blind hole bearing pushers to install the new bearing correctly. Without the pusher set, when you attempt to install the second bearing, you run the risk of pushing the first bearing back out of the correct position. After the first bearing is installed, you leave the pusher in place to hold it while installing the second bearing.
    2020 RT Limited , Marsala Red
    Sep 2014
    USA
    Yep the two piece hub/wheel went away on the 2015 model year.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    This is the method I too would suggest trying. Not fancy or sanitary, but effective. This is a common method in the motorcycle world, which the Spyder rear wheel design mimics.
    The only addition I would make to this suggestion is to heat the aluminum hub with a propane torch. Aluminum grows substantially when heated and at a much faster rate than steel. Get it hot, between 200-300*F, so not hot enough to do any damage to the material. (That starts around 500*F, if anyone is interested.) If you don't have an infrared thermometer, then use the water sizzling method. Flick water or spit on it and if it immediately sizzles (212*F), it's good to go.
    Do this before you begin and pick the side with the easiest access. Once the inner spacer gets loose, then start working your way around. Tapping it smartly, but not in gorilla mode, you don't want to wedge it. That will lead to many other problems. Once the one side is out and the spacer is out, flip the wheel over and repeat on the other side, using heat again.
    When you're putting it back together, make sure to put the bearings in the freezer and get them good and cold. Metal shrinks when cold and expands when warm. So, again heat the wheel before you drop in the frozen bearings. The difference in material temperatures may be enough that they just drop in with no tapping, if not, you have to work fast and be precise or else you can get into trouble.
    2020 RTL SE6
    Idaho
    Quote Originally Posted by Jetfixer View Post
    This may be one time where having the dealer do the work is the better option.
    2014 Copper RTS
    Sep 2014
    USA
    don't risk damaging the hub/bearing areas if you don't have the right tools. It could get costly if it does get damaged from improper removal
    Feb 2012
    Spring City,Utah
    You will need a blind bearing puller. This fits inside the inner race and expands to a tight fit. There will also be a small lip that will grab the inner race as well. Put a little heat on it and it will come out.
    Harbour Freight has a set at a reasonable cost or you may be able to rent one.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Thumbs up Great Thread!
    Does anyone know the dimensions of the inside of the wheel bearing? Found a puller for $30 on eBay. And it would be helpful to know the number on the bearings, rather then pay double getting it from BRP. I have a manual but never looked at the wheel, thought my 2015 would come apart like in finless Bob's video! Thanks for this posting.
    2015 RTL , Red
    Mar 2013
    Quote Originally Posted by SpyderCruiser View Post
    For that - if you have a caliper and access to your axel then measure the threaded end and that will be your bearing id.
    Sep 2017
    Fort Mill, SC
    ID of a 6205 is 1 inch.
    Jul 2010
    Las Vegas, NV
    Default Puller
    Every Harley shop has that puller. I has a set pulled and replaced for $25.00, and a friend bought one, so I see him.
    Joe Meyer
    Sep 2013
    Houston
    You can get a reasonably decent set of blind bearing pullers for under $100
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
