Sway Bar Links
Did some searching but couldn't find anything. I took a peek under me Spyder yesterday. The links going to the sway bar are metal and painted red. I looked on the internet and the forum and couldn't find red ones. Didn't see any writing/engraving on them. Anyone know? It looks like it may have the Baja Ron sway bar, but I didn't have time to look further at it, stuff in the way.
2013 RT Limited.
BajaRon Sway Bar.
Refined Cycle's BPE2 brake pedal extension.
Pedal Box
Ozzie Ozzie Ozzie
Those red links will be BajaRon links with Heim joints in them! Sounds like you've got the good gear under there already! Are the placcy bushes the bar runs thru white? That's gotta be the only tell-tale you are missing so far!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Agree...
BajaRon has made changes along the way on the bar color and the hiem joints. But if yours are metal more than likely they are his and his bars come with them as a kit now. My bar is red and I have the original metal joints (two hiem joints bolted together) now they are one piece. Not many ryders I know only changed the joints but could be....
2012 RS sm5
2013 RT Limited.
BajaRon Sway Bar.
Pedal Box
Cool! I will try to look closer tomorrow underneath.
2013 RT Limited.
BajaRon Sway Bar.
Pedal Box
Get a 5/8th open end wrench and try to fit it over any part of the bar. If it fits, you have the old wimpy bar. If it doesn't, congratulations.
Semper Fi
Originally Posted by mark4Jesus
The bar is black. I will try to look at it closer tomorrow. I was pleasantly surprised to find the mod already done. Makes me wonder what else the previous owner may have done that is not apparent.
I replaced both this past May with Bajaron link and joints.
I received a black bar, red heim joints.
Thanks for the info! The previous owner also put LED's on the mirrors for the turn signals and on the trunk for the brake lights. Now that I am learning what to look for, I am going to start looking closer for any other mods he may have done.
2013 RT Limited.
BajaRon Sway Bar.
Pedal Box
Well howdy!
Finally got to looking closely and the previous owner had Baja Ron's sway bar and links installed! How cool is that! One thing I can check off the list.
2013 RT Limited.
BajaRon Sway Bar.
Pedal Box
Praise the Lord brother! (and the previous owner)
Probably one of the best handling upgrades you now don't have to do!
Happy Thanksgiving.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Happy Thanksgiving.
And Happy Thanksgiving to you brother!
2013 RT Limited.
BajaRon Sway Bar.
Pedal Box
