Results 1 to 9 of 9
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    Default PROBABLY A DUMB QUESTION BUT...
    I may have left my key on and my Spyder is dead to the world. Can I jump it from my truck or do I need to put in on a charger, or trickle charger? I know a lot about Floorboards but not much about the electrical side of my '14 RT. Any help, I'm just trying to get it to my shop for the winter. It will then go on a trickle charger.
    Bryant, Arkansas
    You can jump start it from any 12 Volt Vehicle
    Cruzr Joe
    Jun 2015
    St Charles, IL
    Quote Originally Posted by sealfloorboards View Post
    go ahead and jump it if your in a hurry, some say shut your truck off, after you get it running as soon as you shut it off put it on the charger.
    Mar 2016
    Indiana
    You can jump it from a vehicle, but shut the vehicle off before you try and jump it.
    Jul 2011
    Mitchell, Ontario, Canada
    Depends on how dead the battery is. Most modern chargers/tenders will not try and charge a battery that is less than 10V. In that case you may need to boost it first to get some charge into it. Then the slower the charge rate the better. So a battery tender plugged in for 2 days would be the best way to recover the battery. But then again if you do not want to mess around like that. Boost it and take it for a long drive. Then see if the battery is still alright when you get back.
    2018 F3 LIMITED
    Aug 2010
    Newberg, Or.
    Thanks guys, you've been great help.
    Ride in comfort,
    John
    Jul 2017
    Ramona, CA
    Has anyone had to bump start a manual? That would be a site to see. BigOl Spyder dumping the clutch at 2nd gear.
    2014 Spyder RS-S SE5
    Mods:
    ST Limited Wheels
    RT Handlebars
    Ultimate Seats ST Midrider
    Lidlox Helmet Lock
    Show Chrome Brake Pedal Extension
    Excelvan X-Grip Cell Phone Holder w/USB Charger
    Much more to come......
    Ryder:
    6'-1" - 205lbs - 32"IS - 34"Reach
    Try a third-gear rolling start; why not?
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    Quote Originally Posted by cmbspyderrss View Post
    has to be enough juice to light the ecu and fuel pump
    2017 F3, SM6-basic black, plain and simple
