Transmission filter 1330
Has anyone taken the trans. filter apart to see how much it is full of metal/junk ? and how far can you go over the 28K maintenance time.....
28000 is a good run
why would you want to stretch it?
2017 F3, SM6-basic black, plain and simple
....and if you can't document it was replaced and something happens, not good....
Why....
Don't know of anyone who has taken thier filter apart and there are not that many up to that mileage...you could be the first. I have gone into the fuel filter and after 40,000 miles using many brands of 91 gasoline found nothing in the filter. We have seen engine oil filter colapse and the new ones are caged in mesh but don't know if it was from debris or going too far over the suggested oil change mileage. Considering you are still using the same oil as the engine, clutch and transmission and the engine oil filter is the first to filter, that filter will probably be clean at 28,000 but for the cost (if you do it yourself) worth changing. The cost of things that could fail if that filter stops working will be a lot more.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
We have done it once on the RT already and will need to do it again in about 8k. Here is a video if you need it. Pretty simple. You do not need BUDS to burp the system.
http://dochumphreys.wixsite.com/roadster/install
Just scroll down to the filter change....
Thanks Doc for the link and Video on the HCM change...
Doc, Thanks for the video on changing out the HCM filter. It was a motivator to change the HCM filters and now after having changed two on the RTs , I will have to order some more from BajaRon so I can get ready for the wifes F3T.
She is coming up on 20,000 so one more oil change this Fall, and then we will change it out along with the 28,000 mile oil change next year. It looks like there is a cover over the HCM on the F3, but less tupperware to remove, so hopefully its a quick change.
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
It says video not found
SpyderLovers Sponsor
Oil filter collapses (as far as I know) have been caused by (1) installing the filter backwards so the oil has nowhere to go (probably very rare). Or (2), the poor quality OEM filters in the 2008-Mid-Year 2012 Spyder models (not so uncommon). Again, to my knowledge, this was not an issues with clogging but rather a deodorization of the poor quality filter medium used in the early OEM filters, coupled with the fact that there was no internal reinforcing structure as is found in every other filter that I know of. This was most prevalent in filters left in place well beyond the 4,500 mile recommended service interval or well over 1 year without being serviced. But not in every case.
To my knowledge, this was only true with the OEM BRP filters from 2008-mid-year 2012. No aftermarket or post Mid-Year 2012 OEM BRP filters have suffered this fate (other than the backwards installed filters)
Originally Posted by manxman
I intend to change it, just curious if anyone found metal in the filter. Always took filter part on aircraft engines to check for foreign matter........
I am hoping that someone will take one of these filters apart. I do not want to destroy a new one to find out as they are too expensive for that. I get asked all the time if there is an actual filtration medium in this filter, or if it is just a wire mesh. I would like to know myself.
Trans filter
I will take mine apart and report back of any findings. In fact I must order one from you....
No problem. I can ship it out to you today. I will be VERY interested in your findings. You are doing everyone a service.
Thanks!
I cut mine in half as I too was curious. There is indeed a filter media in there. Flat panel. I did not find any metal shavings but it was dirty. To my untrained eye, looked like wear bits from clutch material, not metal.
I am glad someone has done this. Customers have asked me what is inside these 1330 trans filters. I did not want to cut a new one open to find out.
Of course the clutch is a wear item so having some material trapped in the filter is expected.
Thanks for the info!
Trans filter
Originally Posted by ofdave
28000 is a good run
