Results 1 to 12 of 12
    Active Member Samir221's Avatar
    Jun 2014
    Deltona, fl
    Default Shark 1400 motorcycle speakers wired remote beep
    Hi i purchased and installed the speakers and i love them the only problem is the annoying beep caused by the wired remote when i try to change the input or control the volume. Can that beep be turned off and if it can how ? Or is it a problem with the remote? Any help would be greatly appreciated. Thanks
    United States
    I threw the remote back in the box and just used the wired controls. Might check your manual or contact Shark. They are pretty good folks...
    Default SHARK
    Quote Originally Posted by Roadster Renovations View Post
    ... He is using the WIRED REMOTE ..... what are your wired controls if Not the Remote ............. To the OP, I've had two sharks and never heard any beeping ..... Mike
    United States
    Sorry, you are right, BN! Have never had that happen on mine.
    Jun 2014
    Deltona, fl
    I connected the amp to the daylight running lights( the strip led ones) so it can come only when the bike is on. Do u think the amp is not getting a good ground connection that way?
    I even tried the other remote and it is doing the same thing. Loud beeps whenever i increase the volume, change the input or even when i turn it on!! ������
    Default beeping
    Quote Originally Posted by Samir221 View Post
    About the POWER source ??? I have not encountered any interference from my NUMEROUS LED's ..... however I haven't used them for a power source involving RADIO's !!!!! ..... The ground connection is critical imho , so make sure you have the best you can ...... I would try a different power source for starters ...try it even if it's just to test this Theory temporarily .............good luck /.... Mike
    Jun 2014
    Deltona, fl
    Thanks!! I did try and connected it directly to the battery and it is still doing the same thing. Everytime i change the input or lower/increase the volume a loud beep comes out of the speakers!! I sent an email to sharkmotorcycle and also called amazon and they said to ship the unit back to them and that is what i am doing now. Also after further inspection of the unit the screws on the amp looks like they have been messed with and the speakers have some minor scratches as well and the screws look like somebody tempered with them as well so i won’t be surprised if the unit is a refurbished one. I should have inspected it initially before doing all this work. Oh well sending it back to amazon tomorrow and going back to square one to figure out what stereo to get next. Thanks again !!
    Default SHARK ISSUES
    IMO.... you got a unit that was probably returned ( and not checked or re-furbished ) and they just re-sold it !!!! ..... Unfortunately some sellers ( not many ) are Piss Poor at what they do .... Me and lots of others here have been happy with ours .... Mike
    United States
    Not sure what happened there with your unit, but it might have been one of the two that I sent back due to not having enough clearance for the heat sinks. I burnt one out fairly quickly, got a replacement, then a couple of weeks later the replacement went bad also. It did not say in the instructions, but I figured out that there needed an air gap on the back so I added 2 flat washers to each hole. This offset the unit just enough to flow the air through. Have hundreds of hours on the third unit now with no problems. They never gave me one minutes' problem about the exchanges. I then had one of the speakers start rattling so I contacted them again. They then sent me not one, but two speakers. I can't say enough good things about the way Shark has treated me. Hope they get you straightened out.
    Also, I ran a separate dedicated circuit directly from the battery with an in line fuse and a shutoff switch. Now, when I turn it off, it is completely off. No battery drain that way. And, the amp is so hot, it is excellent for putting fast food in the frunk to keep warm for on the way home.
    Jun 2014
    Deltona, fl
    Given that i ordered the unit through amazon i have to return it, get a refund and then order a new one. They said they can’t just ship me another one because they are not the sellers of the product and they are not sure if there will be new units available to ship from the manufacturer. I did email shark and i am waiting for their response as well. Amazon did email me the return labels but i am going to hold on till i hear from shark maybe they can recommend a quick fix. Fingers crossed!
    Active Member rpatsh's Avatar
    Sep 2012
    Spokane, WA
    Mine beeps also!
    2015 F3s White
    BRP Drivers and Passenger backrest
    Blue Ridge windshield
    Corbin Saddle Bags
    Jun 2014
    Deltona, fl
    Quote Originally Posted by rpatsh View Post
    Mine beeps also!
    Glad to hear that i am not the only one! That is an annoying sound and very loud as well. Hopefully it is just a feature that can be turned on/off!
