Results 1 to 25 of 30
    Jul 2017
    Woodbine, Iowa
    Default Life of the Drive Belt
    If a person watches the belt alignment and has no damage to a belt what is the normal mileage or life of the drive belt?
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    INDIANA, USA
    Default Drive Belt
    A very good question. Anybody have belt life issues?
    May 2017
    Mesa, Arid-Zone-A
    Without damage, I would replace the drive belt based upon age and where the vehicle lives. If you store the spyder in a garage and only ride it in nice weather, I think the life would be indefinite. If you keep the spyder outside, exposed to the elements, especially heat and sun, then 6-7 year life is probably what you will get.
    Semper Fi
    Default BELT LIFE
    Quote Originally Posted by gerald37 View Post
    If I get less than 250,000 I'll be surprised ............... Mike
    Long life for sure--100,000 plus--IF--you stay away from those pesky rocks--or install a rock guard.
    Jul 2017
    Woodbine, Iowa
    My Spyder will is never left outside only on a trip. It will always be maintained and service and never misused. It is not rode in the winter if the roads are bad. I do ride in cold weather with heated gear. About 20,000 miles a year. I will trade it off around 50 to 60 thousands miles so it don't sound like I will have to replace a belt if it don't get damaged.
    Is the belt Guard a good item to install?
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Don't buy yourself needless trouble, don't even bother thinking about it! These belts are generally good for hundreds of thousands of miles or more & there are similar belts out there now that are over 20 years old! Just do the normal specified maintenance (which for the belts, isn't a heap!) & just get out there & ......
    Ride more, worry Less!
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Didn't help me. Still had a stone pierce the belt with one fitted.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    IIRC, there have been a couple of ryders who reported theirs broke something north of 100k. When I was talking to the Spyder project manager at Homecoming about shielding the belt he said if it was enclosed it would tend to run hotter and the life would probably only be around 60k. That leads me to believe that 100k+ is about as good an estimate as there is.
    Default Tough one....
    We have had many belt related threads here but cannot remember any to do with high mileage and being worn out. All other problems we have had discussed here...rocks, cuts. burned, to tight to loose teeth missing etc. Most don't even keep the spyder long enough for that to happen...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2015
    forrest above Reno, Nv
    First farkel was the belt/rock guard. Maybe not 100% effective but probably 99%
    Kaos
    2014 RTS , Circuit Yellow
    Sep 2012
    Stetson, Maine
    Replaced my belt at 50,000 miles. 80% of teeth where cracked. Causing a weird noise coming from the belt when belt warmed up.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Nov 2012
    North Las Vegas, NV
    Not sure if spyderann01 is still on the original belt on her RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default BELT LIFE ????
    Quote Originally Posted by safecracker View Post
    Do you know what the Tension was on that belt ??? ......... Mike
    May 2016
    Sun City West, AZ
    She is also the one I thought would be the one to ask with about 118,000 miles on her last one.
    May 2017
    Mesa, Arid-Zone-A
    As I eluded to in my previous post, heat is the killer of rubber. Here in Arid-Zone-A we replace car/truck tires every 6-7 years. Lots of tread but sidewall cracking will happen as the tires rot from the inside out. Ever wonder why you see lots of road gators in the desert? Rubber belts are no different. They will rot with heat over time and crack into a useless mess. They can "look" ok on the outside while being rotten in the middle. Just do a very close inspection and look for cracking of the rubber. If you find cracking, you are on borrowed time. Having said that, these belts a tough and will take a lot of abuse. I just choose to have a good belt rather than take the chance of being stranded by one that fails.
    Semper Fi
    Jun 2010
    Las Vegas
    I have the original belt in the 14 RT with 123,000 miles on it. I did break a belt in my 10 RT around 35,000 miles though.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Found it! It was a post by Buckeye Chuck 54.
    http://www.spyderlovers.com/forums/s...=1#post1303061
    Wasn't a broken belt, but teeth starting coming off at 108,000.
    Default HEAT & RUBBER
    Quote Originally Posted by canamjhb View Post
    I'm not so sure there is much if any RUBBER in our drive belt ...... Mike
    Active Member mcurtright's Avatar
    Sep 2015
    Yulee fl
    Just had my 15 rtl in for 19,000 mile service
    mechanic said my drive belt has excessive wear
    On the way home now makes growling noise when
    letting off throttle belt looks ok to me no rock holes or teeth
    missing. Wondering if I should take it to another
    dealer and chalk it up to them putting the belt too tight or what
    Faribault, MN
    Quote Originally Posted by mcurtright View Post
    Sounds like a plan, have the 2nd dealer check alignment and tension both. My '13's over 22 k belt looks new.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Sep 2015
    Yulee fl
    Ok thanks with exception of replacing the rear tire
    this particular dealer is the only one to touch it since new
    because they suckered me into the maintenance plan
    Sep 2012
    Stetson, Maine
    I would check the cogs on the belt. As I posted earlier in this thread mine had 80% of these cogs cracked all the way thru. Mike I run my belt.around.120 to 130 lbs. Bruce
    New to Sue and I
    Oct 2011
    Kalamazoo, Mi
    Default belt life
    Safecracker, Don't wish you problems, but glad to hear that I'm not the only one with what I consider premature wear from drive belt. Mine gave up the ghost @ 49K, ALL the remaining teeth were cracked all the way through; dropped 19+ out all at once and I too ran my belt in that same kricket range. I was accused of being abusive to my belt; I do ride aggressively.
    Will be doing what Mike and others have don and that's lowering the on ground readings down towards 100# on the cricket gauge.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Sep 2015
    Yulee fl
    Well I guess my problem wasn't the belt
    looks like transmission crapped out. Goes into
    gear but won't move forward or reverse. just makes
    grinding noise drive pulley on engine side
    won't attempt to move
