Results 1 to 3 of 3
Thread: ECU
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    Default ECU
    Looking to buy a ECU from wrecked 2016/2017 RT or F3L that I can have re-flashed,
    Thanks in advance!
    Please pm if you have one.
    Dray
    Default Would hope not....
    that there are any in the junk yards but you can put the word out to the used motorcyle parts guys (google) and they will shoot it over there network across the country and get back to with where and how much. Otherwise check with the local or cheapcycleparts.com for a better price but not near a used part....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    NorCal - Northbay
    Not sure that even once you have the new ECM "configured" for use on your ride (I'm pretty sure you have to have this done BEFORE you send it off to flash it) that you can switch back and forth between the two, since I believe there can be only one ECM that the spyder will recognize....
    Chuck
