No Remove Gas Cap
Has anyone used one of these on their bike? Someone had it posted on another site. Interesting idea. Wife have factory installed gas cap like this on her 2014 Escape.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2014 Can Am Spyder RT Limited - Pearl White
2010 Can Am Spyder RT - Full Moon
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
mAKE yOUR oWN
Gas Cap
Originally Posted by BLUEKNIGHT911
I've been using them for years , for my gas door installs for the GS - RS - ST seats because you don't have to undo them in the small hole for that door ..... I've seen them lots cheaper on E-bay ..... Mike
Blueknight911
will they fit on a 2016 RT?, thanks for the reply
Joseph
Which one?
Do you happen to know what vehicle the ones you used were made to fit? Or possibly manufacturer part #?
Thanks, Dan
Well...
Here in CA some are not shipped and the elephant nozzels are a pain as it is but I like to fill the tank by slowly going the last bit till it bubbles out the vent slots something you can't do with thses caps...but hey..! When my arthritic hands can no longer twist the cap I may be in the market...
2012 RS sm5
I wonder if that cap will even work with the Ca. nozzles?
Bob
2011 RT-S SM5 - Black
Your right
Bob
You may have to go to specific gas stations with the least emcumbersome nozzles. I saw on that same link that Stant also has a cap but specifically says not for CA and a few other states.....
2012 RS sm5
FITTING
Thanks, Dan
I believe 99% of the screw type gas caps have exactly the same thread size and pattern ...ie not vehicle specific ..... My Saab cap fit my Ford Mustang fine .... it also fit my three different Spyders.....hope this helps .... Mike
FITMENT
Originally Posted by GRIPMAN
Blueknight911
Joseph
See my post #10 ..... Mike
Well, I learned something new today. Not in the market though. Like Chupaca, I like to fill to the last drop and use the same method.
How do those caps handle the spit back that occurs when the tank is nearly full? It's a challenge to get that last gallon in without gas being spit back out the filler.
2014 Copper RTS
Originally Posted by SteveandBelinda
it s works well with gas door have it on my rs now...
spit back
I used mine for few years before I got my RT and did a larger door .... I never noticed any " spit back ". and I fill my tank until it's at the lip ...... Mike
With the CA nozzles, you can't see the vent slots anyway...unless you cheat and hold the vapor recovery piece back against the spring.
2014 RTL Platinum
There you go....
Thats the way we have to do it here. They used to make a slotted plate you could jam on to hold it back...gonna look for one ... or make one...
2012 RS sm5
I think it is NOT a good idea because it would be WAY too easy to overfill.
Or under fill since you can't SEE what is going on.
But since Mike thinks it is OK, I am obviously wrong.
STUPID COMMENTS
