Results 1 to 8 of 8
    May 2017
    Mississippi
    Default 09 RS Seat Modifications
    09 RS is my first bike and I do love her but the comfort level on the seat pushing forward is killing me lol.. In the next couple of years I plan on upgrading but its not possible at this time. Neither is a 500.00 new seat. So my question is has anyone Modified their actual stock seat. I found a kit but I am kind of afraid of cutting up the original esp if I plan on trading in a couple years...... Anyo
    A common complaint about the stock riding position. More like crotch rocket--IMO--and I had both an 08 and 09 version. We put handlebar risers (3 to 4 inch and not the OEM 1.5 inch). You may have to do a search to find them--but a more upright seating position may improve your ride. Good luck on your hunt.
    Default Welcome , welcome....
    We have a vendor/sponsor here...motorcycle dave and he sells a gel kit you can install yourself for 80.00. Many have gone to the local car seat guys and they can modify your seat so it is more comfortable. I have the comfort seat but look long and hard to find a deal on ebay, amazon, here. Most will level the seat and leave the passenger a bit higher giving you some support and 2" more space...
    ​2012 RS sm5
    Aug 2012
    CO
    Other than looking for a used "comfort" seat, you might ask locally if there's a motorcycle saddle shop that can recontour a stock seat. They can peel back the cover and shave off some foam to "dish" out the stock seat area.
    JLohPhotos
    2008 GS , Millennium Yellow
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Firstly I'm probably not the best person to ask as I actually didn't mind the stock seat on the RS.
    However on a long ride earlier this year the seat foam did give up the ghost and never really recovered so I got one of "Motorcycle Dave's" Gel inserts. When I fitted it I also replaced some of the original foam at the sides and padded it out slightly further towards the front to stop my thighs from rubbing against the seat edge. Far more comfortable now with the mods.
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    When I got my '09 I knew the seating position was not going to work for me. I took a different track. I put handle bar risers on and invented the Seal RS SE5 Floorboards. I ended up sitting upright, much like the F3 position. Problem more than solved. check it out on my website.
    Ride ib comfort,
    John
    Linden, CA
    Default YES I CAN HELP
    You have a simple to cure problem, It will be much easier if
    you can call me so I can explain what to do,
    209-887-3283 feel free to call 9:00AM to 8:00PM 7 days a week
    Ride Safe
    Dave
    Quote Originally Posted by tsandifer View Post
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Default 09 comfort
    I also have a 2009 RS SE5 and am interested in improving comfort of mine.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
