Page 16 of 22 FirstFirst ... 6121314151617181920 ... LastLast
Results 376 to 400 of 541
  1. #376
    Sep 2015
    Yulee fl
    Those curious about front sprocket stripping out
    on rt yes. It happened on mine this past Monday.
    Oddly enough I just had 19,000 mile service done
    the week before and dealer said drive belt was worn
    out. I have a 15 rtl by the way.
  2. #377
    Jul 2017
    sarasota, fl
    new pulley yesterday, after these were noticed
    pic of pulley at 3400 +/- milesP1010927.jpg
    clean spot is a thumb print
    pic at 3517 miles a couple days later
    now 3672 a new one, can only hope it won't happen again
  3. #378
    Sep 2013
    Houston
    Quote Originally Posted by mcurtright View Post
    Yes, I have had to give the bad news to a couple RT owners myself during the multipoint inspection part of a service visit. Manuals and Automatics do not seem to matter.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  4. #379
    Active Member Bruiser37's Avatar
    Jun 2016
    Tucson Arizona
    Red face Front Sprocket Inspection
    Quote Originally Posted by SpyderAnn01 View Post
    Doc, have you heard of many F3T or Limited having this happen? I had only heard of it happening on 2015 F3 and was hoping that they had fixed the issue in 16 or 17 or on the T or Ltd. models.
    Problem exists in all 2016 and probably 2017 Spyders. Just replaced front sprocket on 2016 F3-T at 16Kmi... just missed grenade stage by few miles. 90% of spline gone to rust dust. My clue to problem was a couple months of increasing louder high pitched whistle when closed throttle engine braking. This suddenly turned to loud metallic thrashing... this is final stage indicative of immediate grenading. Immediately push it to a dealers shop is only option if you aint stuck in the hinter land.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
  5. #380
    Jul 2017
    sarasota, fl
    I think an inspection of the front sprocket should be done at a minimum 1500 mile intervals.
    It takes at most 10 min to remove and replace the cover and have a look.
    Maybe take a pic for comparison to the next inspection.
  6. #381
    Jul 2014
    United States
    Quote Originally Posted by ofdave View Post
    I'm going to see if an inspection mirror will work without removing panels. I will try both the RT and F3. Glad you caught it before it grenaded and got it replaced!
  7. #382
    Jul 2017
    sarasota, fl
    Quote Originally Posted by Roadster Renovations View Post
    let us know if the mirror thing works, good idea
    yeah, good to have new-but the new one has the same part number and mfr. date. as the one replaced.
    I may be going through this again in about 3000 miles.
  8. #383
    Sep 2013
    Houston
    If you know where to stick a flashlight and your Eyeball, you can inspect the pulley without removal of any panels. RT or F3. I do not use a mirror although it might help.
    I have long thought of adding a Milwaukee inspection camera to my tool kit and this is one of the jobs it would be useful for.
  9. #384
    Jul 2016
    Huntsville Ontario
    Been following this thread. I have a 16 RTL only about 5,000 km. Which panels do I have to remove to see the front sprocket? Pictures would be appreciated since I ama not very mechanically inclined.
    ....brian
  10. #385
    Jul 2017
    sarasota, fl
    Quote Originally Posted by BrianO View Post
    ....brian
    can't answer for the RT
    but I'm sure you'll get your answer soon
    just keep an eye here
  11. #386
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    ....brian
    If if you look at this Video he removes the left hand panels
    once the bottom panel is removed the sprocket can be seen just to the right to the opening covered by the grill
    The panel removal is the same for all RT models
    https://youtu.be/zVulKP4_GaU
    Hope this hope
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
  12. #387
    Sep 2013
    Houston
    If you look from the rear of the bike, along the bottom of the belt forward toward the sprocket, and place a flashlight below the sprocket, you can see enough of the face of the sprocket to see if there is red dust or not. You do not need to remove any body panels just to check. We check the sprocket on every bike that comes in for oil change / annual service.
  13. #388
    Jan 2013
    Glendale AZ (formerly Oz, Albury NSW)
    Quote Originally Posted by gnorthern View Post
    I still have two questions.
    1. Everybody seems to agree that the clunking when shifting is bad. As I new driver I have heard it but unclear as to what causes it. Can somebody tell me how to avoid clunking?
    2. Will towing a trailer make this problem worse? Eventually I want to get a pop up trailer (no lectures about how after market trailers voids the warranty), and want to know if that is a bad idea with a F3-T.
    Thanks.
    1) "Everybody" who said clunking is "bad" would be quite wrong.
    The clunking occurs during the gear change when the drive is not connected to the output sprocket, because the clutch is disengaged.
    Motorcycle gearboxes are constant mesh and ratios are changed by sliding "dogs" (very coarse teeth on the side of gears) which engage with matching holes in the next, adjacent gear, or by engaging with splines on the shafts which hold the gears.
    The only effect of the clunk is that a small amount of hardened gear material might be dislodged on occasions, but this is caught by the oil filter or by the magnetic drain plug. The clunking will not affect sprocket wear, or enable it, since it takes place while the drive is disconnected from the sprocket.
    2) I'm sure there will potentially be more wear on the drive belt while towing a trailer, but it's not a big deal for the people who do it.
    Have fun
  14. #389
    May 2017
    Adelaide Australia
    Quote Originally Posted by Trevor G View Post
    Have fun
    Gents, I have 8500kms on my F3L.
    I inspected my pulley, and see no red dust, however I have a lot of grey dust. Can that be from road dirt? Or is it grey metal??
    2016 F3Ltd , Red
  15. #390
    Sep 2013
    Houston
    Grey is road dirt and belt dust. Completely normal. The iron dust from the splines oxidizes very quickly and shows up as red on the pulley. Sounds like yours is fine so far but keep checking it.
  16. #391
    Mar 2013
    Clarksville TN
    Did a pulley inspection on my wife's 2015 F3 and saw there was just a bit of red dust. I explained to my dealer that I would like to be pro-active and they replaced the pulley and bolt. (at about 5K miles) I couldn't ask for better service from my Clarksville, TN dealer. I'll keep an eye on it from now on.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2023 Corvette Z06
  17. #392
    Active Member Navvet's Avatar
    Apr 2016
    NC
    Well .... Looked and we don't have any red dust, but we have developed a screeching / grinding noise when accelerating. Seems to be coming from the engine area on the left side.
    Calling the service department tomorrow AM to see when we can bring it in and get it checked out.
    This is on our 2016 F3 Ltd SE6
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
  18. #393
    Jul 2014
    United States
    Just serviced our 2014 RT and no sign of red rust at all. Original pulley and it now has 48,000 miles on it. Most of those miles are two up and some pulling a trailer. No sign of wear. Checked on the mirror thing and didn't really work very well. Think the best way to do it is to reach up and stick a finger in one of the sprocket holes and see what gets transfered. Grey = Dust, good to go. Red = iron oxide from the sprocket splines, replace.
  19. #394
    Jan 2017
    Long Island new york
    Default pully cover removed..
    Anyone here remember seeing a pic of lamonsters bike with the pulley cover removed? he painted the pulley to match the bike I think, but I cant find the pic. It looks like the cover is just left off. Looked cool and made inspections simple. Anyone know where that pic is?
  20. #395
    Active Member EricP's Avatar
    Dec 2017
    Atlanta, GA
    If I missed it in this thread, sorry and please point me to the correct post number or so covering my topic, but...
    ...does anyone know of any owners with any sort of the belt dampers, that also has had their sprocket replaced?
    Was just wondering if those dampers might possibly mitigate reasons for sprocket failure. No clue just was thinking. If it’s been thought of and addressed, then never mind. :-)
    2015 F3 , Stock I use the Extended Brake Pedal Silver with black stripes and Can-Am Red/Orange accents
  21. #396
    Oct 2010
    Quote Originally Posted by Sweetwater View Post
    I found this
    Eddie Sheppard
    Poole Dorset UK
  22. #397
    Jan 2017
    Thank u! What do we think??
  23. #398
    Jul 2017
    sarasota, fl
    I think it looks good, kind of industrial exposed pulley.
    It would be difficult for the average owner to remove the pulley, unless you leave it on to paint it.
    Only works for the F3-too much would be left off on other models.
  24. #399
    Member Madmartigan's Avatar
    May 2016
    Chattanooga Tennessee
    Default Sprocket was replaced under warranty.
    I am at Whites Cycle in Chattanooga. Told them about the red dust on the sprocket and how the sprocket will fail at any moment. They had not heard of this problem but they were willing contact BRP about it. BRP told them to replace it under warranty without them even looking at it. They ordered a sprocket and today I am here getting it installed. They installed it and when they took it for a test drive the belt keep drifting out of alignment. They contacted BRP and they advised them to replace the belt because since the splines on the sprocket had worn and changed the position of the sprocket, it caused the belt to wear unevenly. They are replacing the belt now and hopefully I can get out of here some time today. Everyone here at Whites Cycle have been great.
    Anyone that gets their sprocket replaced be sure to check your belt and your belt alignment.
    I used to think it was a terrible thing that life was so unfair. Then I thought, "what if life was fair, and all of the terrible things that happen to us came because we really deserved them?" Now I take great comfort in the general unfairness and hostility of the universe.
  25. #400
    Jul 2014
    United States
    Quote Originally Posted by Madmartigan View Post
    Glad you caught it and BRP was right on top of the repair with no questions asked! Sounds like the belt somehow warped. Maybe we should insist on a belt replacement when the red rust occurs and the sprocket is replaced??
