Results 1 to 7 of 7
Thread: Trailer Wiring
    Sep 2015
    New York
    Default Trailer Wiring
    I just purchased a dart trailer for my 2017 F3 T and I am wondering what I am going to need to be able to run my lights. I still have to buy the hitch and the controller but what else do I need ? I know that the trailer has a flat 5 pin connector. Any insight would be great.
    Active Member sylvester's Avatar
    Aug 2017
    arkansas
    you need to install a 4way isolator and i'll tell you tomorrow what else needs removing couple of plug and plays just forgot which ones ha ve to look and see
    Sep 2015
    New York
    Default what else ?
    Quote Originally Posted by sylvester View Post
    I received my hitch today and as I suspected the directions are next to useless. Do I need to remove the passenger backrest and the plastic piece under it to get to where I need to be ? I also think that I need to remove the rear fender (2 pieces ) as well ?? I have been told that I need a converter to go from 4 wires to 5 ??
    Aug 2017
    arkansas
    don't know about removal of the tupperware but you really don't need the 4 to 5 converter just the 4 isolator , now my brother did both 4 way isolator and the 4-5 converter i did not works fine
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by cobraswinger View Post
    Did you get BRP's hitch or someone elses? If you got BRP's then you might want to consider getting this for the trailer.
    https://leadersrpmshop.com/can-am-ne...622-710003227/
    Currently this place is out of stock. You'll have to find it some place else. And you'll have to get it wired into the trailer so it will plug right into BRP's plug.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Aug 2017
    arkansas
    have the brp hitch i'll get you a number for electrical conn in tenn. they make the harness
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default 2017 F3 S Traier harness
    Does anyone know if there is a trailer harness that will work on a 2017 F3 S?
    2021 900 Ace , Black & Gold
