Mirror
I had mirror off, and was putting it back on, and broke the top plastic catch. Not the ones with the wire, but the top one that slides on. I called parts guy, and he said I needed whole new mirror assembly. I said no way, it's a little clip held on with 2 screws. He then said he couldn't figure out what part I wanted, I needed to find the part # and call him back. I'm about ready to find a new dealer. Can anyone give me the right part number please, so I can do his job for him ? Thanks
Ozzie Ozzie Ozzie
Talk to Lamonster or one of the other Forum Vendors of this sort of thing & get yourself a set of Magic Mirror Mounts - they do away with the fragile & fiddly placcy mounts & replace them with rare earth magnets that make removing & replacing your RT Mirrors a breeze, even one handed, but holding them more securely & with less inherent chance of vibration. Check 'em out at magicmirrors.shop & watch the vids, but remember that's their 'home site' in Tasmania, Australia - you can get them quicker from the local vendors like Lamontster & other Forum Vendors
Ps: you should be able to get replacement Mirror mounting 'pellets' from BRP or cheapcycleparts locally too, but why would you? They're only going to break again....
Agree....
but just in case....
Top one is 219800158 and cost 7.62
Bottom one is 219800156 and cost 14.42 includes clip
Bottom forward one is also 219800156
Part # and price from cheapcycleparts.com......
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Marr, you need a new parts guy.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I changed to the magic mirrors I can mail you the parts that you until you get the migic mirror, just PM me your mailing address and I will send them out.
I thought the magnets in the Magic Mirrors mess up the temperature and fuel gauge readings ?
IBA #47122
2020 RT Limited Asphalt Grey
Had mine for a month or more and have not seen any change in either one. almost 2k miles so far
Mirror
I ordered Lamonster’s magnetic mirror mounts. Thanks everyone
Not if you put them on right. Mine messed my gauges up initially, and all I had to do was reverse the magnets (flip them over) and the problem disappeared. They work great!
FLIPPING MAGNETS
I find this very interesting .... Magnets usually have two Poles a North and a South ( they do make Magnets with multiple poles in the same magnet !! ) they both produce the exact same Magnetic Field ..... Do the instruments know which is which ??? , even if they did , why would it matter both Poles produce the same field ............. PS my magnets are encased in a steel cup and only project the field out from the magnet to the metal plate ....only about 5% are projected from the rear ( or case side ) ...... Mike
