Results 1 to 5 of 5
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Default fluttering dash lights
    haven't been on the bike for a few days. started it up this evening to go for a ride and the illumination lights in the cluster were fluttering. stops after a couple minutes. did it twice this evening. everything else was fine. first time this bike has done anything goofy in the 2 years I've owned it. new battery this spring and used alligator washers at the terminals. 2012 rts
    Dec 2013
    Check every earth connection you can find!! And the dash/instrument plugs, plus anywhere you've touched or anyone else has touched recently... it's likely to be a loose connection somewhere.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Dec 2015
    Oakley Utah
    Hey Peter, the only earth connections should be the tires .... oh, you mean ground!
    2014 RTL Platinum
    Sounds like a loose connection--as mentioned above. Let us know what it was when you find it.
    Invalid Emails
    Oct 2015
    started the bike up this morning for a ride over into the eastern panhandle, and nothing, no fluttering dash illumination lights. not going to stir the pot and just leave it alone. because what can go wrong usually does with me. gremlins!
