Results 1 to 11 of 11
    Aug 2008
    MA & NH
    Default Oil blowing out of fill spout
    Anyone have this issue ? Not a lot, cap was on tight. This seemed to occur quite a while after my oil change (800 + miles). Wasn't over filled. Dealer will be checking it. (2016)
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    I had a similar problem and I thought that the dipstick was screwed on tight - it wasn't.
    George
    2017 BMW R1200R
    United States
    Possible bad O ring? If it's an F3, there have been a few.
    Aug 2008
    MA & NH
    Quote Originally Posted by NautiBrit View Post
    It was tight, has happened more than once. Also had someone else check it after me to be safe.
    Hadn't heard about the F 3 issue, that's what I was thinking but it seemed too simple.
    Apr 2015
    Lodi WI
    Default Over filled by a couple of ounces
    Happens under hard acceleration. Suck out about 6 ounces and see what happens.
    Quote Originally Posted by Saluda View Post
    Aug 2008
    MA & NH
    Quote Originally Posted by Dennis in Lodi View Post
    Are you suggesting under filling ?
    May 2017
    Mesa, Arid-Zone-A
    You could be over filled. Make sure you follow the exact steps for checking engine oil. If not done correctly, you will get a false reading which will make you think the oil level is low when it actually is full.
    Semper Fi
    Aug 2008
    MA & NH
    It's a pain but I'm going by their exact procedure to check oil level. Have not added any oil, dealer did the last service.
    There is no guarantee all the technicians at a dealership are up to date on the engine oil capacity of the 1330 engine. I know for a fact -- 1/2 qt overfilled at my 28K service.
    May 2017
    Mesa, Arid-Zone-A
    I believe the Can Am oil change kit has 1.5 Gallons (6 Qts) of oil. The 1330 engine calls for 4.7L or 5.0 Quarts of oil. Please confirm my understanding your self. But if your pimply faced technician just dumped all the oil in the kit in your bike then you will be over filled....
    But, again, go through the proper oil level check to verify what you have. The good thing is that, once the level is correct, the 1330 engine is known to not loose any oil between changes. Let us know how you make out......
    Semper Fi
    Aug 2008
    MA & NH
    Default Just got it back
    According to paper work, replaced dipstick tube. Warranty, no charge.
