Results 1 to 16 of 16
    Mar 2016
    Olathe, KS
    Default Differences between 2015, 2016 & 2017 RTL's
    Looking to buy my 1st Spyder. I've found some new left over RTL 2015's and 2016's but wanted to know what the differences are, if any, between the 3 years 2015, 2016 & 2017.
    thanks in advance,
    john
    May 2012
    Texas
    Default Differences
    Only difference I know of is that in 2017 they offered a later model Garmin GPS. Also, not as easy as just swapping out the heads. The mount and harness are different as well. Lots of work/expense to upgrade. Newer model is 590 offered on 2017. 660 is standard on 2015 & 2016.
    Colors.
    Mar 2016
    Olathe, KS
    Thanks for the responses. Anything different with the auto clutch or brakes or anything mechanical?
    Wasn't there a change to the final gearing in there somewhere, brought about by the change from the tubular rear swing arm to the rectangular rear swing arm (so the OE Tow Hitch would fit?!) & the associated change to the RT's rear sprocket?? Or did all the NA LTD's (US/Can spec Spyders) have the rectangular rear swing arm & RT rear sprocket from the models' inception?? I thought you North Americans scored a change that the rest of the world (AU/EU spec models) avoided cos we got the RT rear sprocket on all the F3 Ltd's anyway??
    Jun 2010
    Las Vegas
    On the 15 you have to wait for the message to come up before you can start and in 16 you no longer have to wait. Just hit the Mode and start
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2015
    Myerstown, Pennsylvania
    Ipod plug was changed at some point too. Mine has a USB plug. I'm not sure what the 15 has.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    The differences between those model years are pretty much just minor "tweaks"...
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    im assuming that 2015 users that wait cant have an update done by the dealer?
    otherwise someone would have posted it here.
    [joyce & irvin toms]
    Apr 2015
    Oregon/arizona
    Default 590 garmin
    Quote Originally Posted by jzb54 View Post
    Hello, the 2015 rtl was equipped with the 590. 2016 was 660 because of 590 shortage. I own a 2015rtl.
    GOS member (Girls On Spyders) currin20fan's Avatar
    Jul 2011
    Beaufort, SC
    Default 2015 RTL.
    Quote Originally Posted by 3-togo View Post
    I also have the 590 and I don't have to wait for the menu to come up b4 I can start.
    2015 RT Limited , intense Red Pearl
    Active Member El Dorado's Avatar
    Jun 2017
    NorCal
    I have a 15 and once the bike has been ridden for a bit, the next start does not require waiting for the message. Just press the eco button and hit start...... nice feature for sure. But does not work on first start of the day or after stopped for long
    2015 RTS
    Replaced Catalytic Converter with Lamonster Pipe
    Rivco Flag Holders
    Tricled wideview mirrors
    Garage door opener
    Zumo GPS
    Ultimate seat
    F4 windshield with vent
    Doc's belt damper
    Value Accessories RAM mount
    Baja Ron sway bar and Links
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    Default Just made deal on 2015 RT
    Found an RT at nearby dealer. Test rode it. Sneaky salesman knew he had me. Will pick it up next week.
    Jan 2015
    southern WI
    Quote Originally Posted by starrider60 View Post
    2016 RTS , Pearl White
    Aug 2016
    Central Illinois
    Default Tnose darn snealy salesmen
    and of course cause it didn't happen without one. Which I have never done either.
    Lots of good information and folks here. Enjoy that ryde!!!
    My sneaky salesman all ready had the paper work filled out when I got back from the test ryde. I'm sure I was his easiest catch ever.
    Ranman42
    Active Member trikerbiker645's Avatar
    Apr 2016
    wi
    SpyerAnne01, not all 2015's need to be waited on to start.... My buddy and I bought one a couple weeks apart and we just get on and start it up and go. dave
    Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
