Results 1 to 5 of 5
    Active Member msherwood's Avatar
    Manteca, CA
    Default plug and play LED
    Question for those of you that had added the ground effect LED lights? I am by far no electrical pro but is it as easy as they say plug and play or do you have to run wires everywhere?
    Thanks in advance for your feed back
    Jan 2015
    southern WI
    Not exactly sure what you're asking, but you'll certainly need to run wires from wherever you mount the lights to wherever you plan to access power for the plug n play connection. The electricity surely isn't gonna "jump" from the plug to the lights without a wire in between. If you're referring to the term plug n play, then yes, it means that the wires are meant to plug in at a certain junction in a harness, with a bridge to the original wires and your accessory.
    2016 RTS , Pearl White
    Jun 2010
    Las Vegas
    The ground effect lights are easy to install just watch where you place them. We installed them for a customer and promptly ruined the longest strip by putting the jack over the strip
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    i make my own harnesses and buy leds in bulk and cut to custom lengths.
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
    Active Member Phantom888's Avatar
    Jan 2011
    Quakertown Pa
    I also make mine own using bulk rolls of led strips and wire. But there are a few companies that make puck like lights with harnesses. I just found it much cheaper to do it myself. There are plenty of vendors out there that will install led lights for you. Spyderquest, Maggie Valley, ETC....
