Ozzie Ozzie Ozzie
Wasn't there a change to the final gearing in there somewhere, brought about by the change from the tubular rear swing arm to the rectangular rear swing arm (so the OE Tow Hitch would fit?!) & the associated change to the RT's rear sprocket?? Or did all the NA LTD's (US/Can spec Spyders) have the rectangular rear swing arm & RT rear sprocket from the models' inception?? I thought you North Americans scored a change that the rest of the world (AU/EU spec models) avoided cos we got the RT rear sprocket on all the F3 Ltd's anyway??
On the 15 you have to wait for the message to come up before you can start and in 16 you no longer have to wait. Just hit the Mode and start
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Ipod plug was changed at some point too. Mine has a USB plug. I'm not sure what the 15 has.
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
The differences between those model years are pretty much just minor "tweaks"...
im assuming that 2015 users that wait cant have an update done by the dealer?
otherwise someone would have posted it here.
[joyce & irvin toms]
I have a 15 and once the bike has been ridden for a bit, the next start does not require waiting for the message. Just press the eco button and hit start...... nice feature for sure. But does not work on first start of the day or after stopped for long
2015 RTS
Replaced Catalytic Converter with Lamonster Pipe
Rivco Flag Holders
Tricled wideview mirrors
Garage door opener
Zumo GPS
Ultimate seat
F4 windshield with vent
Doc's belt damper
Value Accessories RAM mount
Baja Ron sway bar and Links
Just made deal on 2015 RT
Found an RT at nearby dealer. Test rode it. Sneaky salesman knew he had me. Will pick it up next week.
SpyerAnne01, not all 2015's need to be waited on to start.... My buddy and I bought one a couple weeks apart and we just get on and start it up and go. dave
Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
