Results 1 to 15 of 15
Hybrid View
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default RT Sidecase rack?
    I've surfed spyderlovers and the web in general to see if I can find RT sidecase racks. By this I mean a rack that goes on the top of the side cases so one could place a bag here on top of the side case. One could then bungee it to both the rack and passenger handrails if required. Anyone know of anything like this?
    Another option is to put some kind of rub rails on the top of the side cases so I could put a bag here and bungee it to the passenger handrails without scratching the top of the side cases. Anyone know of anything like this?
    Regards,
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Quote Originally Posted by robhowen View Post
    Regards,
    Rob
    It's surprising that nobody has come up with something like this. Seems to make sense even for light items.
    Then of course they could invent a custom made bags for the carrier and custom straps to secure the bag.
    Greg
    2015 RT Limited (White)
    Default Try this....
    They made them for goldwings and some of the others like the venture, kawazaki, cavalcade etc. Try checking there , they may work on the RT...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I came up with this solution for securing extra items on the back seat when riding solo
    http://www.spyderlovers.com/forums/s...eat-Helmet-etc
    Hope this helps
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Apr 2015
    Tucson, AZ USA
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Not a rack, but I've used these on my BMW bags.
    http://www.twistedthrottle.com/bungi...hoC8X0QAvD_BwE
    Bob S
    Linden, CA
    Bob
    I have seen 2 RT's with Harley chrome racks like fit on the Harley side bags on top of theirs,
    there are several companies that make chrome racks that will work.
    Regards,
    Rob
    The way that they're shaped: I'm pretty curious to see how they can make it work...
    Dec 2015
    Oakley Utah
    I would be concerned about putting additional weight on the top of the side-opening side cases. The H-D cases are designed for that; the Spyders' are not. You're also defeating the aerodynamic qualities of the smooth surface of the side cases.
    2014 RTL Platinum
    Sep 2016
    Lewiston , Maine USA
    Just my 2 cents worth But Is the strength of the side case open or closed enough to support that much extra weight? I thought I read somewhere on here about early year Spyders having hinge failures?
    Sep 2012
    Junction City, KS, USA
    Regards,
    Rob
    From your description I envision a rack that is cantilevered over the side case. So nothing is touching the side cases, but makes a wide platform behind the ryder. Is that what you mean? F4, a SL sponsor, makes a rack for the back of an F3 Spyder. This sounds like something they could develop if there's sufficient interest.
    PrairieSpyder (Patti)
    Apr 2015
    Tucson, AZ USA
    Default Maybe
    I looked at the F4 website and I don't find what you are speaking of. However, given your description it is something I was considering as well. I found a BMW GS owner that did a DYI project that is similar to what you describe. He created a metal shelf that wrapped around the rear of his bike giving him mounting areas above each of his side bags and behind his tail bag.
    Rob
    Quote Originally Posted by PrairieSpyder View Post
