FOBO Trike
Has anyone experienced problems with their Fobo Trike app for iPhone since upgrading to EITHER IOS 11.0.2 OR FoboTrike app version 2.16?
Specifically, not syncing.
TIA
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
I JUST OPENED MY APP UP AND IT IS FINE..IOS 11.2
2017 F3T Black
2016 RT LTD Black - Traded
2015 Indian Chief Vintage Red
Hope you mean 11.0.2
Did you happen see if the app is syncing and giving updates?
2014 RT-S
I upgraded my 6s to 11.0.2 last night, Paladin. I started the app in the kitchen where it was “disconnected”, and just wandered out toward the garage about 60’ away, and it started synching with the F3 on the way there. By the time I reached the internal garage door, all tyres and my air bag were synced. I didn’t even know Bluetooth would sync that far away.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Thanks Pete
Something is up cause I tried with my wife's iPhone using 11.0.2 and Fobo app 12.6 and it didnt work either.
The chances of ALL probes dying the same time is like NILL
Well guess it's time to call Fobo
AJ
Pete
2014 RT-S
Originally Posted by PaladinLV
Thanks Pete
AJ
I’m running FOBO Bike vers. 2.16 (I assume that’s what you meant to type above) as well, AJ. Very odd !
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
SORRY Paladin...IOS 11.0.2, FOBO version 2.16
still working fine
tom
2017 F3T Black
I had a few wheels not wanting to sync and just changed the battery out and they worked even after it showed the battery was still good. It also has a .2 pound error on all the tires. when I remove them they show a .2 pounds of air in the fobo app. There is something wrong and I suspect it has to do with the temp reading affecting it. On my app I also have my wifes Harley.
2017 F3 Limited
Good news, AJ.......I have noticed a couple of times that synching takes significantly longer, for reasons I have never discovered.
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Fobo won’t sync
I got a new phone 6s. Running 11.2.5
i have tried everything to sync the Fobos.
turned phone off.
Deleted app reinstalled.
Switched to another tire
took battery’s out
what else can I do, I am beyond frustrated.
Thanks
Ben
Hope this helps........
turned phone off.
took battery’s out
Thanks
Ben
Changed batteries the other day on one of my spyder's FOBO's and it wouldn't sync back up to the tire. I did everything I could think of but still no sync. Finally out of frustration I put the FOBO on my truck tire stem just to see what would happen. I'm running 65 psi in my truck tires. As I screwed on the FOBO to the stem I heard a "pssss..pop" sound and the FOBO came on and sync'd up showing 65 psi. I took it off and placed back on my spyder and it worked just fine and is still working. Don't ask me why, I'm not that smart, but it worked.
I had the same experience when I updated to the X model.
Finally decided to test the batteries.
All THREE were DEAD!
Who would have thought all three would die the same time? But they did!
So if you have not yet and are able to, check the batteries.
AJ
turned phone off.
took battery’s out
Thanks
Ben
2014 RT-S
Batteries
Weeks of frustration, and all it was was three little Batteries.
thank you for your help.
AJ
Glad I could help!
AJ
2014 RT-S
Electronics are strange !
Wife's Fitbit synchs well 97 % of the time. That other 3 %.
FOBO Problem
My rear tire monitor was not showing up, so I replaced the battery. Wouldn't recognize, so I took it out of the system, now I have to reinstall. Not done yet, hope this does it. Before, when I would touch the phone to the sensor it would just sit there spinning. Saying Wait.
2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
