Results 1 to 11 of 11
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I searched for info about replacing battery...
    ... on my 2010 RT and have watched video... when I replace the battery do I need to do anything with the nanny/electronics? Or can I just remove and replace the battery and then just fire it up and RYDE?!?
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Active Member Bandera's Avatar
    Bandera, Tx
    When I replaced mine on my 2010, I just replaced the battery. Did not have to mess with the nanny. I just needed to reset the clock.
    Michael
    W5MWI
    USN Vet - RM1
    Member: VFW & American Legion
    2020 Spyder RT-L - Jupiter Metallic Blue Chrome
    Aug 2016
    Default That is good news....
    Quote Originally Posted by Bandera View Post
    Michael
    ... and thanks Michael. Gonna go take the battery out and replace it before our trip to Arkansas.
    Jim
    Jul 2014
    Mint Hill, NC
    Remember, when removing the old battery disconnect the negative cable first, and when installing the new battery connect the negative cable last.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Apr 2017
    North Central Florida
    And make sure that your new battery has a full charge BEFORE installing it.
    Aug 2016
    Default UPDATE: Don't you love it when...
    ...you get some good news?? Removed the battery today (2010 RT) and took it to Advance Auto. Had guy check it out... it's a GOOD BATTERY showing all the right numbers. Didn't have to buy a new one. Put battery back in (followed tips in this thread) and added cable for new heated vest. Checked to be sure vest was heating before reinstalling tupperware... Buttoned everything up and started byke to be sure it runs... it does... Ready for our trip to Arkansas and back - about 2000 miles with ryding while we are there. I appreciate the tips and advice everyone!
    Jim
    Default BATTERY CONNECTIONS
    Quote Originally Posted by BigGuy66 View Post
    Jim
    The terminals on our Batteries are notorious for coming loose ...... I have always put STAR washers ( with the teeth inside ) on the bolts before tightening them .... they will NEVER get loose by themselves ...... Mike
    Apr 2017
    .I appreciate the tips and advice everyone!
    Jim
    You didn't mention charging it up.
    After all of the messing around, that might be a very good idea.
    Aug 2016
    Default Looks like I can ryde today...
    Quote Originally Posted by Easy Rider View Post
    ...to get that battery charged... and then trickle charge while sitting and waiting for going to AR.
    Jim
    Nov 2013
    Oro Valley Arizona
    Jim
    Surely that is not the original battery. If by chance it is I would change it regardless of the readings. You would be way overdue.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    Depending on several variables, the rule in battery testing and life is:
    if the battery tests bad, it is bad.
    If it test good, it could still be bad.
    Battery testing is not a perfect science. Knowledge of it's history is critical for estimating the amount of life left in it. If it has lived on a tender when not in use, it will probably last much longer than one that wasn't. If it was dropped or in an accident, that should be taken into account. If it was ever allowed to go completely dead, that is not good either. Many variables. If you want to be reasonably sure you won't have any issues, get the new battery. It can save a lot of grief.
