Results 1 to 18 of 18
    Active Member bfmtrader's Avatar
    Apr 2010
    Indiana
    Lightbulb Big Wheels on Spyders
    I just saw on Pinterest pins that show Spyders with outrageous front and rear wheels on them. How do they do it and bypass the wheel sensors so it does not throw fault codes, and go into limp home mode? I do not plan on doing anything like this to my F3S, I am happy the way it is. Wanted to throw the question out there.
    Dec 2013
    When you say 'BIG', do you mean big as in 'larger diameter' or big as in fat, or a whole lot wider??
    I don't think you'd fit anything much larger in dia OR fatter on the back without doing significant mods due to the two sided swing arm restricting the space available back there; but up front, sticking a fatter wheel on without disturbing the sensors is easy... just not too good for the power steering tho!! It doesn't like having to work at turning anything too much wider than OE width tires!
    There again, given enough impetus & sufficient $$, there's not really too much that's absolutely impossible to do, IF someone really wants it to happen?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default BIG WHEELS
    a computer guru friend told me a while back that you can go into the ECU and change things.... how? you ask... i have no idea... you may want to call BROWARD MOTORSPORTS and ask them how they do it....
    here's 2 examples... saw these at the BIKETOBERFEST @ Daytona Speedway back in 2011...
    Dan P
    SPYD3R
    Default How about this....
    ​2012 RS sm5
    Default WHEELS AND TIRES
    Quote Originally Posted by bfmtrader View Post
    The tires they are using ...are probably 35 aspect tires .... the Kenda's are 55 aspect tires ..... so they are probably the same circumference or close enough for the Nanny to say it's OK ..... PS , the nanny reads the rear tire only .......... Mike
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    The look on these bykes is nice but I am not sure that I would want to Ryde one, no strike that I am sure of it.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    it's not the tires, it's the wheels
    here's a set of 20inch on Ebay if you can't live without them
    http://www.ebay.com/itm/F-3-CAN-AM-S...tVz3GI&vxp=mtr
    2017 F3, SM6-basic black, plain and simple
    Apr 2016
    Bloomington, Minnesota
    NO WAY the wheels are worth THAT much!
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    What would be the advantage of larger tires or wheels?
    Jul 2017
    sarasota, fl
    Quote Originally Posted by sealfloorboards View Post
    you look cool!
    doesn't matter how it drives as long as you look cool
    Apr 2015
    Green Bay, WI
    Default Same size oversized tires
    If the sensor input is coming off the rotor or hub it won't mater what size the tires are as long as they are equal ratio in sensor outputs,. by theory one could put John Deere tractor tires (if they had the room) one (1) revolution might travel twice the distance but as long as all rotor-hub sensors turned at the same speed the distance of the ground covered won't matter.
    Darrell
    Active Member heyharris1's Avatar
    Jul 2017
    umatilla oregon
    To me personally I don't even think it looks cool. It for people with more money than common sense.
    Jim
    2012 Can am Spyder RT Limited
    2013 Chevy Camaro SS
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by heyharris1 View Post
    Jim
    Or the very young
    d
    Active Member NVERLAST1's Avatar
    Nov 2011
    charlotte,nc
    I bought my wheels all three are the same size. no adj to nanny. yes I love the looks but now my bike is more stable in the turns.
    Jul 2017
    sarasota, fl
    Quote Originally Posted by NVERLAST1 View Post
    sharp
    so what size are they and what tires?
    is it a lot higher off the ground?
    Nov 2011
    charlotte,nc
    Quote Originally Posted by ofdave View Post
    sharp
    All three are 20 inch wheels with a custom pulley. Yes the bike is higher off the ground .
    Invalid Emails
    May 2016
    Columbia,tn
    They may look nice. But the bad part is the Tire is only half as thick as standard tires. So when they start going flat you need to get off the road faster and get stopped. I saw one run plum off the rim one day on a BMW. Not a pretty site when the rim was grinding off on the pavement at 65 miles per hour and the Tire is passing the vechicle going down the highway.
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R
    If you don't mind spending the money, you can change anything in the ECU that you want with BUDS Megatech!
    http://www.brpdiagnostics.com/brpbud...echlicencekey/
    2016 F3T SM6 - Wife's Bike - Blank Canvas
    2017 Kawasaki Concours 14
    2016 Victory Magnum - Mods in progress
    2013 Suzuki M109R - Has a few mods
