Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Default Got my new tires
    Finally got my new tires. Now to find the time to get everything to the dealer to get them installed.IMG_3229.jpgIMG_3230.jpg
    Kuhmo for the rear and Federals for the front.
    2014 ST-S , OEM Yes Cognac
    Default NEW TIRES
    Quote Originally Posted by ARNIE R View Post
    If you keep the Kumho tire at 17 -18 psi you get a better ride and it will work better in the wet ......... Mike
    Dec 2013
    If you are doing a lot of long hot miles, you might want to run the Kumho on the rear maybe a pound or two higher (max 20 psi) so that it doesn't balloon when it gets hot & give you the same wear pattern as that we see on the Kendas, but if you aren't running in 85F plus ambient temps all the time, then as Mike says, you will probably get the best traction, ride, handling, and braking from 18ish psi back there - you can use the 4psi rule to check that you are close to optimal pressure, or check for even temp increases across the face of the tire tread. Hot strips of tread indicate incorrect pressures - hotter strips on both the edges = pressures too low; hot strips on one edge indicates an alignment issue; a hot band down the middle indicates pressures that are too high!
    When we aren't running in 35-45C plus ambient temps thru summer or I'm not ryding 1000km each day, I run 16-18 psi in my 225/60R15 Kumho Ecsta on the rear & I am expectibg to get 30,000 km plus milage of virtually unparalleled all seasons traction & handling as well as longevity - traction & handling that's likely only going to be exceeded in the dry by a dry weather performance tire like the Yoko's that others recommend. What those may gain in traction over the Kumhos at the right pressure they tend to lose in tread longevity, & I can live with the marginally less traction the Kumhos provide for the substantially greater tire life they return - but then we also can't get many of the Federals & Michelins etc in sizes that fit that you all get over there!
    Oh, & the Kumhos excel at those lower pressures in the wet!! My skid pan braking tests showed about 1/3rd BETTER braking distances in the wet from the Kumhos at that pressure than we got from them at the same pressure in the dry!! Dropping another pound or two made the handling a bit doughy & steering a bit loose, but improved traction and braking distances (especially on the wet) even more! Adding a couple of pounds over 22psi & the wet braking distances went out by something over 1/2 again extra distance, and virtually guaranteed understeer & hydro-planing on barely wet roads!! It's a juggling act, but the more you put in to getting things right, the better your tires will look after you!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2014
    Ga
    Looks like a good combination. Post a review of their performance next time.
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    I have the exact same tires on Cocaine, and you should see a noticeable improvement in your handling on turns, and because of this, your speed in the twisties will be much faster. I run the rear at 20lbs and the fronts at 18-19lbs. Works for me.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Default MAGGIE VALLEY
    Quote Originally Posted by Bam Bam and Pebbles View Post
    Will I see you again this year ??????????? Mike
    May 2013
    Apex, N.C.
    I was wondering the same thing. Gonna see how fast those new tires will be making you.
    Nov 2014
    Rural Hall NC
    Well gee, thanks guys. It depends on the weather. Not sure but I would like to get up there. If I do I will be looking for both of you. Where you guys staying?
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
    Default THE CABIN
    I'm sharing a Cabin with Buckeye Bleau from Ohio ... Stonebridge RV & campgrounds ....about 1/2 mile east of the Fair Grounds ....... But you can find me at the Fairgrounds ...I'm a Vendor this year ...........Mike
    Mar 2017
    Leesburg, VA
    One quick question - when I pull the back wheel off and deliver it and the new tire to the dealership, do I also need to remove the center hub or belt pulley for them or can they install the new tire with those parts still in place?
    Dec 2013
    ^^ If they aren't up to speed on Spyders, it's probably best if you pull the hub & pulley & the rubber blocks (if you can!) But make surdd you take pics or mark things so you know how it goes back together properly!
    Default TO PULL OR NOT TO PULL
    I HAVEN'T done one without removing the HUB .... But NOW they make the HUB NON-REMOVABLE .... and the machines to remove still work .... folks here have done it .... Mike
    Mar 2017
    Leesburg, VA
    Boy, I am frosted!
    I took my new tires and old ones in to the dealership today and was asked "are these car tires?"
    Yes, I said. Then tried to explain the better properties and characteristics of the "car" tires and how well they are liked and how the Kenda's are despised worse than a used car salesman.
    No deal, liability issues with their "contract" with BRP, etc. Even after the service manager said they would do it.
    I tried a few car tire places and they wouldn't touch them.
    Finally went to a local car repair service that I had used for service on my Ford truck and the guy measures something on the rims and says they can do it, so, I am crossing my fingers and hoping that they can successfully complete this task without trashing the rims.
    On a side note, removing the rear tire did not happen to be as difficult as I had thought it might be.
    Default CAR TIRES & SPYDERS
    [QUOTE=ARNIE R;1307685]Boy, I am frosted!
    On a side note, removing the rear tire did not happen to be as difficult as I had thought it might be.[/QUO . Spyder rims / wheels are Auto type rims .....not Motorcycle wheels .... plenty of Dealers I know of will mount Car tires if you sign a waiver..... I'll bet 95% of all Spyders Dealers ....DON'T DO THE TIRE CHANGE - anyway I don't think those expensive tire changing machines can DO MTC wheels any way .........jmho ... Mike
    Oct 2014
    Bryan, Ohio
    Peter: Have you ever used Dina Beads to balance your rear tire? Neil
    Boy, I am frosted!
    A common issue for those using non-OEM. You have to look around to get someone to do it for you. I have a dealer who thinks exactly the same as above. Being un-mechanical and lazy--I let the dealer put OEM's on. Over 5 different Spyders, I get 20K plus on the fronts and about 15K on the rears. One exception--soft rubber compound on my 2014--got 8,900 on the rear one.
    Dec 2013
    Quote Originally Posted by Neil Rupp View Post
    Not on a Spyder Neil, never needed to!
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    Yeah, I'm probably going to go OEM Kenda's when my tire-change time comes. I don't feel like spending a lot of time sniffing out a dealer/shop that will service my need for non-OEM tires, and me ending up having to do a lot of the work myself and lying about what the rims/tires are going to be used on.
    It seems that I recall that someone on the Forum had a conversation with a BRP Rep at some event, and the Rep said there was NO contract obligation between BRP and Dealers to use OEM tires. It seems that someone ain't telling the truth....either the Rep or the Dealers.
    Quote Originally Posted by HankD View Post
    I don't remember the above conversation--so can't help there either. Anyone know for sure?
    Mar 2017
    Leesburg, VA
    The drama continues,,,,
    Today, I went to the repair shop to check on my tires. Both fronts were outside heating up in the sun as the outside beads had still not seated all the way around. I told the tech that based upon what I had read, he might have to pressure them up to about 80 plus PSI, sure enough, about at 85, bang, they seated all the way around.
    The rear tire, surprisingly, went on far more easily. Tech just pulled the sprocket off and had no issues with it going on successfully.
    So, I cart the tires off to the dealer to be balanced, since I didn't think the repair shop had the proper eqiupment to do an MC type wheel (did not bother asking, stupid me)
    The Can-Am dealer takes a look, checks with the service guy who says no way will they touch them since they did not install them. More liability issues. O-kayyy.......
    I call back the repair shop and inquire about balancing, which they say they can do only on the fronts because the rear needs to be stripped of all extra parts in order to be able (hopefully) on the balance machine. Back home I go and strip the back wheel clean. Back to the shop and drop it off.
    Hopefully, all of this will be fixed tomorrow.............
    Oct 2014
    Bryan, Ohio
    Default Kuhmo
    Arnie: I'm curious on how the Kuhmo rides being it's a very low profile tire. Neil
    Mar 2017
    Leesburg, VA
    Finally, the end (I hope)
    My repair shop got the fronts balanced without issues, however, they could not do the back wheel even though I had removed the hub and bearing. The hole was just too small to fit on the balance machine.
    Surprisingly, the guy offered to take it himself to another local shop in town that had other balancing machines and this one could not get it to fit either. I was about to tell him that I would go ahead and try to locate another generic motorcycle shop somewhere, but he again said to let him try one more place. So he takes it again to another local shop and this one has another balance machine with a smaller shaft. It fits!
    He brings it back to me and home I go with it. Don't know too many shops, if any, that would go thru this much bother and offer to get the work done at two of his competitor's shops to get it done. I was most happy.
    You found a good one.
    Mar 2017
    Leesburg, VA
    Finally got my first ride on the new tires today - did about 150 miles.
    Impressive compared to the Kendas. The engine sounded louder probably because the tires were a little quieter. They handled well and felt smooth - even my mirrors had almost no vibration. Did one 4 mile run at 75 mph and one very short burst up to 86 and all felt very good. Still a wee bit twitchy on some of the curves, but a attribute this to them being new and stiff and will most likely loosen up as the miles increase.
    Ran the pressures at 18 front and 20 rear but this will probably need a bit of tweaking as I ride more.
    Think I will keep the Spyder a little longer now.............
    Default STRIPPING OFF THE HUB
    As far as " Rear needs to be stripped " ....that's HOOEY .... because the newest BRP wheels have the HUB Permanently attached !!!!! and tire shops are not having any issue with it ...... I've seen people here having them done at Walmartr and Costco !!!!......... Mike
