2015 FS-3 SE6 in north Georgia or North Tampa
SOLD
2015 F3-S - Magnesium with orange frame; 2 original keys.
Presently located in north Georgia (Cornelia) but can deliver to Tampa
area as I have two residences and travel occasionally between.
12,500 miles, new General Altimax rear, original fronts (shows how easy I ride this trike)
Custom-built Cogent Dynamics shock w/ remote pre-load adjuster, BRP removable backrest, MBL Innovations rear rack with well-enjoyed Givi top box, trailer hitch w/ isolator wiring harness, Corbin saddle w/ orange piping, Eastern Beaver PC-8 circuit board, Tricled amber/red front fender LEDs, Lamonster handlebar mount mirrors w/ RAM mount, F4 windshield, LED headlight bulbs, BRP steel chopped rear fender plus original fender (the pair work together nicely to keep the passenger dry), heated clothing cable for passenger, built-up foot pegs for passenger.
Will include a stock swaybar with bushings from a 2014RT, which would make a nice upgrade.
Everything works; no mechanical or electronic issues; only cosmetic issue is scuffs on several front spokes from wheel chock interference once when trailered.
Title is clear and in hand-- no liens
Reason: SOLD
Pete Tamblyn
Cleveland, GA
2020 F3 Limited (black)
Time Out XL1800 cargo trailer
2019 Royal Enfield 650 Interceptor
2018 Kawasaki Versys-X 300
2013 ST (sold)
2015 F3-S SOLD
2014 RT-Limited (cognac) SOLD
pre-load adjuster
This is what makes the shock magic: an easy-to-access knob that quickly sets from one-up to two-up for a very smooth ride.IMG_3403.jpg
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
footpeg position
Foot pegs currently in Position 3 (middle). Have additional Position 4 brake rod, and an extra Position 3 rod which could be shortened/lengthened to any other length. Takes under 30 minutes to swap positions, in case you are a two-rider household.
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
sway bar
After reading considerable in-forum on the topic, I see some riders have taken advantage of a cheap handling upgrade by substituting a stock sway bar from a late model RT. Not that big a job to install if you have a safe way of raising the machine 2' off the floor to swing the bar into place.
I have a perfect condition sway bar from my previous 2014 RT Limited, with bushings, which I will include with this package.
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
