Originally Posted by IdahoMtnSpyder
Interesting. I wonder what wire they actually put it on. There really is no PTT circuit per se for the driver headset. There is a very short connection between the PTT button and the PC board inside the left handle switch module. The module is part of the CAN bus and the PTT signal is a digital signal to the radio, which then forwards the signal to the CB unit, or closes a loop in a CB circuit possibly parallel with the pax headset PTT button, which then puts the CB into transmit mode.
That short connection between the switch and the CAN bus is where it was added. It seems that the RF on the line was allowing noise on the line and this was causing the device to trigger error.
Originally Posted by Fire34
with your helmet on how does one hear from the group? Are you able to use the speakers in your helmet? If i were to get one does it have to be from BRP to be able to use the PTT button on the handle bar? Cost etc. Thanks guys
Dave
Dave, I will try and answer as best I can:
1: with your helmet on how does one hear from the group? Thru the helmet speakers when someone keys up
2: Are you able to use the speakers in your helmet? Yes
3: If i were to get one does it have to be from BRP to be able to use the PTT button on the handle bar? Short answer.... YES but there are aftermarket options. Just search for CB options. The CB is a great tool for group riding communication and farther distance then most other systems being used.
Dave
Read my comment here http://www.spyderlovers.com/forums/s...=1#post1357612 as well as the entire thread. You'll pick up a lot of info.
In short you need a helmet headset, either wired or Bluetooth.
2014 Copper RTS
