Hi Erik,
Re: it makes a high clunk / dunk sound when I'm shifting, is this normal?
My '08 CLUNKS and it still bothers me after 3 yrs of riding it. I only get the 'clunk' when going into reverse or first gear.
Re: Sorry for my english
You are doing fine.
Re: I'm a young fellow from Norway
We were all your age once.
Jerry Baumchen
'I'll never forget what's her name.'
'Things are more like they are now than they ever have been before.' Dwight Eisenhower
2008 GS SE-5
I would chalk it up to "newness"
So ... I am reasonably sure continued use / practice will remove that tendency.
Remember also that most riders over-rev their motorcycles when shifting and this is most pronounced in the first two gears. I also fall back into this bad habit when I am tired or distracted.
There is a video dealing with this problem on YouTube by Kevin, a licensed motorcycle instructor who operates MCRider. I believe the short video is titled "Do you have bad habits on your motorcycle?", but I know there are several series of videos specifically addressing shifting habits.
Ride safe(LY), J
You might be able to somewhat minimize the "clunk" by shifting at "neutral throttle" but you won't eliminate it completely.
That's just the way the transmission works.
Going from N to 1 or R is the worst; especially when the engine is cold.
I have a 2012 RS SE5 and it shifts smooth as butter. Doesn't matter if I rev to redline or shift at 4000 RPM. The initial shift into 1st there is a "clunk" and also when shifting into reverse. As long as my oil level is correct shifting is smooth and quick in all other gears up and down. I'd recommend maintaining 4000 RPM or above in all gears. Also, don't let off the throttle when you shift up or down like you would if you had a clutch. Keep steady pressure on the throttle and shift. You might notice the throttle turning itself a bit to adjust.
My '09 always "clunked" when I put it in reverse but I don't remember a lot of noise shifting up.
Ride in comfort5,
John
My 2011 SE5 clunks loudest N to 1st and reverse, but also loud into 2 slight less into 3, 4,and 5 but non the less I hear it and feel it on the footboard. The clunk going up thru the gears sometimes sounds like a chirp. I noticed when cold going up thru the gears (into 2,3,4,5)clunks less than when the oil is fully warm.
one thing I do to keep the clunk noise to more of a min. Is get on the throttle harder right before a shift seems to help out.
I always wondered if there is an adjustment needed to tame the clunk noise down. Mine has 37k on it and doesn't matter if I use BRO oil or amsoil, clunk is the same.
Maybe A BRP mechanic can answer that last paragraph.
WELLLLLLL NOW THAT YOU MENTION IT
And what, pray tell, does that have to do with any noises it makes when you do that ??
PRAYERS
