Results 1 to 6 of 6
Thread: Help!!
    Mar 2017
    Daytona Beach, Fl
    Default Help!!
    I have a 2010 Spyder RSS SE5 and i noticed the "BRAKE FAILURE" scrolls across screen when I was riding the other day. Brakes seem to be working fine. I need to know how to get the error codes and how to reset. Thank You in advance for your help.
    Feb 2012
    Spring City,Utah
    check your brake fluid level and your rear brake pads. Spyder is very sensitive to a very slightly lower fluid levels. The Rear pads wear faster then the fronts for some reason.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Things to check....
    First off get the spydercodes app...it's free and will tell you how to get the codes, what they mean and some solutions.
    Check you were not ryding with your foot on the brake....
    Check the brake fluid level....
    Check the brake light switch..they will stick...
    Check that all the brake lights are working
    Check the brake pads...
    Check the brake fluid sensors (if you can)
    Turn the spyder off remove the key let the computers reset, maybe 30-45 minutes depending on model, re start and see if the warning cleared and does not come back. Could be a glitch or too long on the brakes on a downhill....
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    Download the spyderCodes app. If you have a smart phone. Here are codes: https://lookaside.fbsbx.com/file/err...Z1AjqUtGtVaPSA
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    To get codes: Press and hold MODE button
    Stop on TOTAL HOURS
    Push the FLASH HIGH BEAM rapidly 5 times.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Mar 2017
    Daytona Beach, Fl
    I have checked the fluids and they are full. brake pads are still beefy as there is only 7,100 miles on the machine. I can not find the app you spoke of in the apple app store. I tried the procedure of the headlight flashing switch when in total hours on the gauge and I do not get any codes just the regular scrolling Brake Failure message. What next??
