Results 1 to 6 of 6
    Active Member ralph12345678910's Avatar
    Nov 2015
    georgia
    Default front wheels lift
    I have a 2016 f3t and I can get the front wheel off the ground from a stop and turning left or right is this normal I don't need to take off hard enough to spin back tire to do this. This is a stock spyder with no farkles. Nanny comes on right on corners while ryding slowing it down. Should I be concerned with this
    Very Active Member WackyDan's Avatar
    Apr 2009
    Charlotte, NC
    Low speed lift in a sharp turn is kinda common. Have done it plenty on my 08 and 17. Just get some seat time in and you'll end up doing it less.
    WackyDan - Fun, not crazy.
    Charlotte (Matthews), NC
    Silver Moon SM5 - V35 and V46 Givis, CHAD, Motolight 35w steering lights, Dash Powerlets, Helibar risers, Garage door opener, Eastern Beaver PC-8, Digital voltmeter, Kewl Metal Intake, Evoluzione Sway Bar, RT Shocks and Juice Box PRO.
    *Mower deck in development*
    2008 model -new in crate, April 09
    26,000 miles.
    Looking for other Charlotte area riders to cruise with and compare Spyders.
    HAPPY SPYDER OWNER
    United States
    Leaning a little forward will help that.
    Aug 2013
    Northern California
    That is the F3 version of a wheelie! Kind of fun, but I believe that Nanny will save your back!
    Default Relax....
    Is easy to do and more so with the low end toque on the 1330 engine. You will find you usually auto correct even before the nanny. You will get the hang of it as mentioned above...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    washington state
    If you try to defy nanny then pay the consequences.
    2012 Spyder RT SE5 Brake pedal mod
