front wheels lift
I have a 2016 f3t and I can get the front wheel off the ground from a stop and turning left or right is this normal I don't need to take off hard enough to spin back tire to do this. This is a stock spyder with no farkles. Nanny comes on right on corners while ryding slowing it down. Should I be concerned with this
Low speed lift in a sharp turn is kinda common. Have done it plenty on my 08 and 17. Just get some seat time in and you'll end up doing it less.
WackyDan - Fun, not crazy.
Charlotte (Matthews), NC
Silver Moon SM5 - V35 and V46 Givis, CHAD, Motolight 35w steering lights, Dash Powerlets, Helibar risers, Garage door opener, Eastern Beaver PC-8, Digital voltmeter, Kewl Metal Intake, Evoluzione Sway Bar, RT Shocks and Juice Box PRO.
*Mower deck in development*
2008 model -new in crate, April 09
26,000 miles.
Looking for other Charlotte area riders to cruise with and compare Spyders.
HAPPY SPYDER OWNER
Leaning a little forward will help that.
That is the F3 version of a wheelie! Kind of fun, but I believe that Nanny will save your back!
Relax....
Is easy to do and more so with the low end toque on the 1330 engine. You will find you usually auto correct even before the nanny. You will get the hang of it as mentioned above...
2012 RS sm5
If you try to defy nanny then pay the consequences.
2012 Spyder RT SE5 Brake pedal mod
