Results 1 to 19 of 19
    Active Member SpyderF3-s's Avatar
    Oct 2015
    Menifee, CA
    Default Back in the shop for the second time this year!
    In April the front sprocket stripped out and had to be replaced. (long story on that repair!) Last week I heard some grinding when engine braking. Took it to my local dealer and he said that the other dealer did not put lock-tight on the bolt that holds the sprocket on and it has started to strip that sprocket and drive shaft. Local dealer said I have to take it back to the other dealer and recommended drive shaft and sprocket to be replaced!
    Last sprocket repair took a month! Image how long it will take if they have to replace the drive shaft!!!
    Going to be another month or two without my Spyder and fighting with the dealer to get it repaired under warranty!
    God bless those who serve/served our country!
    Active Member Samson's Avatar
    Aug 2016
    Prescott Valley , Az
    I continue to read the threads here as I am somewhat new to the Spyder world. I think its really amazing that more shops than not APPEAR to not have qualified techs to work on this machine. This does not exactly inspire confidence to own long term.
    Linden, CA
    I agree !!! that is why I do 99% of all my mechanical maintenance and service
    I flat refuse to pay $250.00 to have my oil changed. I can do mine in 30 min.
    Oh by the way I have a 1 ton duly service truck, I can have it serviced 7 times
    for $250.00.... enough said
    Quote Originally Posted by Samson View Post
    Sep 2016
    Parma, Idaho
    Default Driveshaft?
    Quote Originally Posted by SpyderF3-s View Post
    Pardon my curiosity, but what driveshaft? I am familiar with such driveshafts as can be found on the Gold Wing and BMW. But was not aware of a similar driveshaft on a Spyder. I know the RT-SE5 has an Aramid belt.
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Me thinks he's referring to the output shaft on the engine.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Active Member bobnaquin's Avatar
    Nov 2011
    St George UTah
    BRP made a tactical error when they decided to distribute Spyders through the network that was already selling other off road BRP vehicles-Snow mobiles, jet skis, ATV's. The difference in service requirements has plagued Spyder owners ever since. It is what keeps someone like me from moving up to new models, since after 10 years I kind of know what to do with the 104th Spyder ever built. Most of what I know I learned here. After 10 years you would hope that Spyder dealers had learned how to service them but I personally have not had that experience.
    Jun 2011
    Alamogordo, NM
    Samson, I am under the impression that the Spyder Dealer in Prescott Valley is a good and knowledgeable dealer.
    Love that area of Arizona, used to live in Show Low.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Default Bummer....
    Sorry to hear of your reoccurance plus complications. Long waits and poor workmanship seems to be happening in the big multibrand dealers who have techs with little interest in the spyders. I saw this at a dealer I worked at when Honda started servicing outboard motors. The techs would pick up the workorders and set them aside while the worked on bikes. BRP is also known to have poor stock in parts. I had the same issue with the sproket coming loose ( I think the holding bolt stretched) but as I do my own work and it is not covered as a wear item I ordered my parts from cheapcyclepart.com and had them in three days for under 100.00 bucks for the sprocket bolt and washer (recommended to be changed hope they did) and changed it out and back on the road in four days. I do they will get to it cause now they have to pull the engine and trasmission apart to change the output shaft....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    I have heard of some dealers changing the whole transmission if the output shaft is bad.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2015
    Menifee, CA
    Default Shaft and sprocket stripped!
    I contacted BRP and they agreed that I can use my local dealer to do the repair. Dealer said that the entire engine and transmission will need to be removed to replace the shaft. Hopefully it will last longer than 6000 miles like the previous repair!!!
    Oct 2015
    Menifee, CA
    Default Repair Update
    The local shop checked the shaft and said that it was within specs. They will be installing a new sprocket ending in part number 2134. Should have it back with in the 10 days. This is the second replacement sprocket. Time will tell how long this one will last (Original - 28,000 miles, first replacement - 6000 miles).
    NorCal - Northbay
    I find it odd that now that they (local shop) are doing the repair it only needs the sprocket. When at first they told you it would need an output shaft as well!
    Chuck
    United States
    You might want to tell them what Kenny Butler has suggested and does. He has yet to have one come back. (Kenny is a certified Spyder tech in Florida) He uses this:
    https://www.amazon.com/Loctite-Quick...tal+gap+filler
    If there are any irregularities in the shaft, this will fill in the areas. I am now thinking this is the only way to go on this. He lets it set up for 24 hours before putting any torque on it.
    Dec 2009
    West Oz
    Within spec eh? I wonder what spec that was?
    May 2016
    My question to the dealer who said it was within specs would be, "How did you make that determination"? Did they use a "Go/No Go" gauge? Did they mic the splines over pins? Or did they use a ball mic? What is the tolerance and did they mic more than just one or two places? The Loc-Tite product looks like it would be very helpful. The splines would need to be just shy of an interference fit or wear could occur very rapidly, especially if one part was much softer than the other.
    2013 RT-S SE 5
    Dec 2009
    West Oz
    Quote Originally Posted by BoilerAnimal View Post
    That's the long form of my short question above yours.
    The short answer will be: it looked ok (in dim light) and it felt ok with the bolt tightened.
    Oct 2015
    Menifee, CA
    I was reading another threat following this issue and it someone had mentioned about the sprocket being installed backwards. If you look at the picture you will notice no part number! That means it was installed backwards by the dealer that fixed it the first time! Glad I had a different shop work on it this timespyder sprocket.jpg
    Faribault, MN
    Maybe they need to additionally engrave/imprint it with This side OUT...<G> though the part number was probably intended to indicate the outboard side...<G>
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2013
    UK
    Default And it'll be more of the same....
    If a main dealer's engineer cannot correctly fit a sprocket to a shaft then I'm damned if I'd let them strip a motor! Can you imagine what horrendous consequences may occur if it's not done "by the book"? I wouldn't let this guy work on a lawn mower never mind a road vehicle.
