HELP Can't Get Mode to Work.
2013 Spyder STS SM5.
When I turn the ignition on the dash lights up as usual.
I wait for the start message.
Pull in the clutch, Step on the brake. Check the on/off switch is in the run position.
Push Mode and NOTHING happens.
I can't get past mode to start the bike.
The electric parking brake releases and engages.
Turn signals do not work.
Emergency flashers show flashing on the instrument panel but not at the turn signal lights.
In the past the turn signals worked with the ignition on but the bike not running.
Battery is charged showing 12.5V. Had it on the battery tender all night to no avail.
Key is stored out of the ignition switch and away from the bike all night.
Any ideas??
Is there a fuse or relay for the rear turn signals??
Can turn signal problems disable the operation of the Mode button??
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Does anything on the left control pod work?
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
The left handlebar control is disconnected or defective. Likely defective but easier and cheaper to check if it has been disconnected first. Does any of the backlighting of the buttons work?
2018 F3 LIMITED
Mode Switch
Roger & Billy
Thanks for the replys.
The mode and set buttons don't work.
Turn signals don't work.
Can't remember if the backlights work. Will check.
I haven't checked the horn but will as soon I get off work.
Come to think of it, The Left Control switch was replaced by the dealer right after homecoming.
I need to look for a disconnected lead.
David C
2016 F3T
Rear IPS Pack Rack
The Mode, Set, Directional Command buttons and turn signals are all Can bus. They are all connected to a internal circuit board. The Horn and the High/Low buttons and wired direct to their circuits. No Can bus involved. So if the horn works and the button backlighting works. The wires are not disconnected and circuit board is likely fried. Can't test the high/low button unless the engine is running. If the horn and button backlighting don't work. The harness is disconnected somewhere.
2018 F3 LIMITED
Mode Switch
OK, I tested the buttons.
Horn works. Backlight does not work.
Looks like I need to trace the wires and look for a disconnect.
David C
2016 F3T
Rear IPS Pack Rack
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Mode
Originally Posted by Bfromla
Hope that is all it is. Last time someone reported this was after a vandalism trying to steal a tank bag guessing whatever's loose took little time to come on out you gonna diy or try different dealer?
I will first try DIY to inspect the connectors if I can find them without total disassembly of the front end. Then try to find a trailer if needed. I want the original dealer to fix his screwup. Thankfully I have an extended warrantee. Every dealer is a long haul from here.
Its unfortunate as today was to be a group ride and covered bridge tour.
David C
2016 F3T
Rear IPS Pack Rack
Any update? Good news I hope
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
Mode button
I could not get easy access to the connections.
I'm waiting for the dealer to collect the Spyder on Thursday.
I will followup with their findings ASAP.
David C
2016 F3T
Rear IPS Pack Rack
Thx hope all comes out good
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
David C
2016 F3T
Rear IPS Pack Rack
Ah David, many of us have been right there with you once or ....gasp, even twice... remembering the fundamental troubleshooting steps after a mod (inadvertantly) gone wrong sometimes escapes us all. We're so confident we checked that (whichever) step, and discover later that we didn't. Yea though I always recommend a written checklist, I don't always remember to use one....
Glad you got it fixed, found out why it happened, and then shared it with us, ONE day, it will help someone else... Thank you for sharing.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Thanks....
's for following up and letting us know the outcome. But the best part is that it's home and all is well...
2012 RS sm5
Tags for this Thread
